'49 PU 4 speed trans
Old May 10, 2004 | 10:48 AM
Fordolet's Avatar
Fordolet
Thumbs up '49 PU 4 speed trans
I just got a very nice 49 PU. flathead 6. 4 speed trans(floor shift) that grinds and makes noise in all gears. I would like a newer, smoother application to drive daily. I am interested in a three speed with OD. Is this possible and what do I need to do to accomplish this?
Old May 10, 2004 | 05:56 PM
bobj49f2's Avatar
bobj49f2
Learn to double clutch, it's a lot easier than changing the tranny
Check out the page I have on my web site it might help:
Shifting a four speed
Old May 10, 2004 | 10:40 PM
Fordolet's Avatar
Fordolet
In my case, double clutching is not the only issue. I'm determined to update the tranny and or the rearend. I would appreciate any information in that direction and am open to any helpful suggestion or voice of experience. Many thanks in advance.
Old May 10, 2004 | 11:40 PM
mtflat's Avatar
mtflat
It's possible if you're determined. I'm using (putting up with until it fails) my stock tranny - 3 spd HD. When it goes south I'll be hunting a 4 spd OD out of a mid-80's pickup (86-7) or a 5 spd OD from an S10.
Adapter plates are available for applications that need them. Check with Speedway for these.
Old May 11, 2004 | 05:31 PM
Fordolet's Avatar
Fordolet
Thanks for the info mtflat. I talked to Marty at Speedway who presented me with several choices of machining, adaptors, etc. He was a wealth of knowledge. I'm still open to other suggestions esp. from those who have actually hooked up a 3 speed OD behind a flathead 6 on the floor.
