Best Air Filter
Old Feb 12, 2002 | 07:14 AM
Fury's Avatar
Fury
Best Air Filter
Old Mar 25, 2002 | 05:09 PM
usmc1775's Avatar
usmc1775
Best Air Filter
I have hear good and bad things about all the air filters, which on is the best one, for performance and clean air, can you have both.
Usmc1775
2001 psd 4x4 cc
Old Mar 25, 2002 | 06:58 PM
powerstroker250's Avatar
powerstroker250
Best Air Filter
Yes, you can have both. I like the Western diesel foam filter, Amsoil also makes a foam filter. You can look at the AFE magnum which is a good unit as well as the Big Sucker, Airaid and Volant units. K&N also makes a new unit for the PSD. You will just have to seach the web to see what is right for you.
Les
Old Mar 25, 2002 | 07:30 PM
usmc1775's Avatar
usmc1775
Best Air Filter
It is me again, so you believe that the foam is better than the gause kind that K&N use, I know that my dirt bike has a foam, what is what made you go with the foam.
Thanks again, you have been a great help, oh ya do they make a shop man that I can get for the 2001 PSD?
Usmc1775
Old Mar 25, 2002 | 11:46 PM
lodihoseman's Avatar
lodihoseman
Best Air Filter
You can order the shop manuals from the back of your owners manual. They are pretty expensive, but they also cover everything, unlike the chilton or other manuals.
Old Mar 26, 2002 | 02:02 PM
powerstroker250
Best Air Filter
I just have had good experiences with foam so that's what I stick with. Yes, all my bikes and 3 wheelers had foam filters too, so if they are good enough for the abuse you get in the desert, they are good enough for my truck. Check eBay for manuals, usually there are CD manuals available for under $20.
Les
