1978 - 1996 Big Bronco
Shifting Noise
Old May 9, 2004 | 10:06 PM
Rupturedduk's Avatar
Rupturedduk
Angry Shifting Noise
Once again...just trying to get everything out. My truck is auto, and it shifts out of first very hard. When ever i have to put the pedal down and not let up...the car shifts at the right rpm but there is a relatively loud noise once it shifts...I thought was the gear teeth not meshing right at first...but once again not sure. I just hope the tranny's good for now.
'91 Bronco
302, auto
131,402
Old May 10, 2004 | 07:30 AM
fcarruth's Avatar
fcarruth
My 89 did the same thing quiet a few years ago and it ended up being the rear end needing a rebuild. Maybe you won't be stuck with that though. Probably wouldn't hurt if you drained and refilled your rear end fluid as well as check your u-joints on the rear shaft.
Good luck,
Old May 10, 2004 | 10:19 AM
kameronth's Avatar
kameronth
My 88 is acting up like that right now two. The rear end is getting done in a month so I hope it will make a difference!
Old May 10, 2004 | 07:33 PM
Rupturedduk
Alright...that sounds right thanks
