1978 - 1996 Big Bronco
bronco help
Old May 8, 2004 | 04:25 PM
ThirdGen383's Avatar
ThirdGen383
bronco help
hello, i have a 96 bronco, the odometer and trip meter is not working, ive looked in books and i cannot find the wiring for it, im thinking a wire got pinched and snipped under the vehical but i cannot find where its at or how it works, can anyone help, thanks
Old May 9, 2004 | 11:12 AM
bigric's Avatar
bigric
Does the speedometer needle work? If so, you're looking at replacing the PSOM (speedometer/odometer unit). If not, and the ABS light is on, consider the ABS sensor on the rear axle or the wiring going from there to the cluster. Also check the fuses, including the underhood fuses. I've had the underhood fuses wiggle loose and kill the PSOM before.
Here's some info on VSS since you asked:
http://www.gearsmagazine.com/2004-01/2004_1_50.pdf
Old May 9, 2004 | 07:12 PM
ThirdGen383
will it damage anything if the plug on the rear axle is unhooked? all i notice is it shifts a little bit harder
Old May 9, 2004 | 07:24 PM
RTM's Avatar
RTM
That sensor on the back is what controls your shift points by knowing the speed of the truck.. With no sensor the computer thinks the truck is sitting still.
Old May 9, 2004 | 07:35 PM
ThirdGen383
yea, its my dads truck, it doesnt get drivin much, hes over in france for the year, i jus drive it down the street to the store everynow and then, he jsut put a new gas tank in it and maybe accidently knocked the plug loose, it shifts around 3500 rpm, and shifts like its got a shift kit in it, i didnt wanna mess with anything on it
Old May 9, 2004 | 07:38 PM
ThirdGen383
and the speedo doesnt work, i was just wondering if this will hurt anything likethe clutch since is shifting harder
Old May 10, 2004 | 07:41 PM
RTM's Avatar
RTM
I can't really say if it will or not. I can only guess that it can't be good? If its just the sensor connection you can't hurt anything by trying to hook it back up.
