Dipricol Gauges
Old May 9, 2004 | 08:12 PM
AKESPY's Avatar
AKESPY
Dipricol Gauges
Does anyone have these brand gauges installed in their truck ?
I'm looking to install a pyro, boost and transmission temp gauges and would like to know what your thoughts are.
I realize that Motorhaven sells the Isspro brand but I like the looks of the Dipricol gauges.
Thanks,
R
Old May 9, 2004 | 08:25 PM
psdwanabe's Avatar
psdwanabe
They are both quality gauges. I got my eye on something like this. Automatically shows highest temp and alarms at a preset temp set by you. And with 4 probes I can put one on each bank, 1 pre and 1 post turbo.
Old May 9, 2004 | 10:45 PM
Tadashi's Avatar
Tadashi
Those probes are for each cylinder I thought. If you put them in other places like post and pre turbo you will only have the pre turbo showing in auto mode since it will be the higher temp right?
Old May 9, 2004 | 10:56 PM
Hayapower!'s Avatar
Hayapower!
Thanks,
R
Give Motorhaven a call first, with the brand/style of gauges you like, and see if they can get them for you.. It'll help support this site, and they may be able to get you a decent deal as well.. They'll work with you
Old May 10, 2004 | 01:43 AM
Superduper's Avatar
Superduper
Di Pricol gauges
Thanks,
R
Yes, I have these gauges, and I installed them about a month ago. I used the A pillar mount which makes a "factory" look and is very clean. I think they look really nice and the lighting in them is perfect (back lit), which is important when you have them up there staring you in the face at night.. They match the the original dash gauges just about perfect too. You will like them.
Get em! SD
Old May 10, 2004 | 06:08 AM
AKESPY's Avatar
AKESPY
Get em! SD
Thanks for the reply...I take it you have the black face gauges ?? Do the bulbs call for green covers ??
R
Old May 12, 2004 | 08:45 PM
Superduper's Avatar
Superduper
gauges
R
Yeah, they are black face, black bezel. The bulbs were used just as supplied and attached to the gauges. The numbers on the new gauges, when lit, are the exact color of the original truck gauges.
You'll like, S.duper
