General Automotive Discussion
Best chain lube
Old May 9, 2004 | 07:18 PM
FERacing66's Avatar
FERacing66
Question Best chain lube
Hey im back and am wondering which chain lube you folks use for your atv's and bikes? i was using PJ1 but it was a mess! it was almost impossible to clean up and took me 2 hours. im now using bel-ray and am very happy with it, it seems to work just as good and you dont have to spray it on the sideplates. plus, just hit it with some water an your done. anyway what chain lube do you folks use and why?
Old May 10, 2004 | 11:30 PM
robduval's Avatar
robduval
Talking
the bel-ray chain lubes are a good chain lube. i use the pj1 just cause its a little more water proof. the best way to put it on is ride the bike for about five minutes to get the chain warm then put the bike up on a stand so you can spin the rear wheel. slowly spin the wheel while spraying on the pj1 so you don't fling it every where. now let the bike sit for twenty minutes or so and the oil sets right up and won't get sprayed all over your plastics.
Old May 11, 2004 | 07:47 AM
FERacing66's Avatar
FERacing66
yeah but isnt the pj1 a pain to lean up? i like the bel ray also beause i an just spray it on the roller links and thats it but the pj1 is a better if your in water the bel-ray omes off pretty easy if you go through water.
Old May 11, 2004 | 08:37 AM
Hossy's Avatar
Hossy
I use the bel-ray, you should apply it to the inside of the chain so centrifical force forces it out through the rollers. Now if you run an o-ring chain the rollers have sealed in lube and the chain lube just keep the plates lubed.
Old May 11, 2004 | 08:39 AM
PureGrunt's Avatar
PureGrunt
I use Putolene on all my bikes and chain drive go-karts. Its great stuff. It sprays on like a white liquid (like the stuff on a BRAND NEW chain) and after about 20 mins, it's on there and it won't come off.
I put it on one of the sports bikes I had and headed off on a ride. Well it rained for about 4 hours straight and that night when I checked the chain, it was as well lubed as when I'd left home.
Another bonus is that hardly any flicks off. I clean more road grime off my rims that chain lube. Thats not the case with any other products I've used.
Hope this helps
Old May 11, 2004 | 12:39 PM
bob-63-292's Avatar
bob-63-292
Any of the "won't fly off" lubes will be a bear to clean up. I used wd-40 and paper towels on the rims - comes right off - before I figured that I needed something better.
If you are riding on the street, the better bet is to use a continuous oiler. Some like the "Scott Oiler", but mine broke during a long ride (along with several others who were on the same ... long ... ride). I switched to a little electric oiler, a Chaintech. Had to order it from a place in England (don't know if they have a U.S. distributor yet).
With the chaintech, I was able to take a 6,000 mile trip (5 days) and not touch my chain. Pretty cool, huh?
A friend of mine makes a device called the "HawkeOiler" (see www.hawkeoiler.com), which is another on-the-road lubrication system. Check it out.
Bob
Old May 11, 2004 | 09:09 PM
robduval's Avatar
robduval
FER your c key is definately toast huh. if you go slow and let the pj1 set up afterwards it's not to bad.
Old May 11, 2004 | 09:19 PM
Ultramagdan's Avatar
Ultramagdan
R K o-ring chain lube is tuff. I use it on my KLR 600 and on our go cart. The stuff doesn't fling and sticks like glue. It takes a little more time to apply then the foam but it works very well for my extreme applications.
It comes in a bottle and it pours like molasses.
Old May 12, 2004 | 06:28 AM
BigGunZ's Avatar
BigGunZ
Best stuff I've tried is "chain wax". I forget who makes it but it goes on liquid then hardens to a wax-like substance. It doesn't fling off at all.
Old May 13, 2004 | 08:42 PM
FERacing66's Avatar
FERacing66
hey what are the adavatages of an o-ring hain?
Old May 13, 2004 | 09:26 PM
Ultramagdan
They outlast regular chains. Nearly all of the sport bikes use them as well as my thumper. They stay lubricated longer and handle shock better as well. You can ruin them if you immerse them in sand all the time but they usually will still outlast a non o-ring chain. They cost a little more but many bikes require the use of o-ring chains.
Old May 17, 2004 | 12:57 AM
FERacing66's Avatar
FERacing66
hey thats prettey cool i didnt know that o-ring hains were that cool. i have one on my yamaha.
Old May 17, 2004 | 06:06 AM
bob-63-292's Avatar
bob-63-292
They also induce more drag, which is why some road racers do NOT use O-ring chains on the track. Of course, road racing is an expensive hobby...
Bob
Old May 17, 2004 | 10:03 AM
TigerDan's Avatar
TigerDan
Chain lube? Chain? What's that? I have a shaft drive bike-no muss, no fuss, and smooth!
Old May 17, 2004 | 11:01 AM
FERacing66's Avatar
FERacing66
yes but chain drive is lighter, more direct, and more relilabe than than shaft drive just a little more matience. you lose just a tad of power with a a shaft drive.
