Sponsored by: Kumho
Vibration
Old May 8, 2004 | 11:38 PM
jbjb5081's Avatar
jbjb5081
Vibration
<HR style="COLOR: #666666" SIZE=1> <!-- / icon and title --><!-- message -->
I have a 95 F-150 Super cab sb 302.I just bought this truck and noticed a slight shimmy when the truck gets to 28-34 mph.It does this acc/ coasting& in neutral.I feel it in the body of the truck not in the steering wheel.I have balanced the tires ,had new u joints put in.Drive shaft checked for balance.Moved front tire to back ,back to front.Changed diff fluid.Front shocks.New carrier on drive shaft.Rotated the shaft 180 x 2.checked motor mounts.When going down or up a hill it is not noticlble.Just around 30mph on flat smooth road.
I have read alot of the post on this subject.Hope-ing for some new ideas.
Thanks
Old May 9, 2004 | 08:11 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Sounds like you've checked plenty of stuff so far. I would check out the frontend: wheel bearings, ball joints, tie rod ends, I-beam bushings, radius arm bushings and steering damper (if it has one).
Old Jun 17, 2004 | 10:22 PM
jbjb5081's Avatar
jbjb5081
Took it back to the drive shaft shop.Had them balance it.Fixed my problem.......
wpnaes
S. California Chapter
33
Dec 23, 2016 10:51 PM
7283-F250
1983 - 2012 Ranger & B-Series
Jun 5, 2016 02:19 PM
Michael Roark
Jun 27, 2015 11:16 AM
95F250NUT
Offroad & 4x4
18
Jul 23, 2004 05:05 PM
spencercj
Jun 4, 2003 07:52 AM
