4.2L Engine Problems Please Help!!
Old May 10, 2004 | 09:08 AM
//mjeff's Avatar
//mjeff
Coolant Level is Normal, but very dark. I am going to replace the fuel pump and filter today.
Jeff
Old Oct 2, 2004 | 09:44 AM
DTruax's Avatar
DTruax
97 f150 4.2l can anyone help?
i had a used 4.2l engine installed in my truck. does not run right. i am fed up w the dealer that istalled it. nothing but a headacke, i took it to my buddy who runs a garage.
heres the problem, idles fine, under accelation no power spits and spudders. when the rpm are almost maxed the engine smooths up.
he has replaced plugs, camposition sensor, removed cat converters, replace both upsteam o2 sensors. adjusted timing compresion test all cylinders (all well), by pass the knock sensor. there is no engine codes
any ideal please help
feel free to call i will call you right back so its my bill (EDIT BY MOD)
david
thank you
Edit: David, Welcome to FTE! Avoid posting your phone number.
Contact David here or PM, or e-mail if you need to.
Thanks,
Brian
Old Oct 4, 2004 | 07:08 PM
//mjeff's Avatar
//mjeff
Check the 90 degree elbow made of rubber behind the upperintake on the left side, mine melted. Its about the size of a half dollar and costs about $6.00 from ford. You can't see it, reach your hand behind the upper intake and feel around while the truck is on... if you hit it, it will hiss... because air will leak out. Replace that elbow! If you don't your truck will gradually run lean and ping.
Jeff
Old Oct 8, 2004 | 11:50 AM
Busa01's Avatar
Busa01
Originally Posted by travlnman
Just disconnect the battery, go have a sandwich, and hook it back up, and away you go.
Darn, no wonder I could never get any codes cleared. I keep forgetting to eat the sandwich AFTER i disconnect the battery.
Tom
Old Oct 8, 2004 | 01:30 PM
horizonhuskies's Avatar
horizonhuskies
Tom!
you owe me an email or IM buddy!!
Garrett
Old Oct 8, 2004 | 01:35 PM
scrimbaby's Avatar
scrimbaby
So you replaced that part and is your truck running better because I have the same problem with mine as you did yours and I have replaced over $600 worth of stuff and still haven't gotten it fixed.
Old Oct 8, 2004 | 01:49 PM
Busa01's Avatar
Busa01
I know Garrett, i've just been so busy with the house that I haven't been doing anything except settling in. Now that I'm all settled, i'm back to normal.
Scrimpy, who are you talking too?
I'm going to check this "supposed elbow thing-a-ma-jig" out as well.
Tom
Old Oct 8, 2004 | 01:53 PM
scrimbaby's Avatar
scrimbaby
I was asking mjeff cause he is the one that started this thread and then he comes off this elbow thing and was wondering if that fixed the problem or not. I have tried feeling around for this elbow thing I can't seem to find what he is talking about.
Old Oct 8, 2004 | 02:19 PM
Busa01's Avatar
Busa01
I'm not sure about this whole elbow thing. Perhaps he struck a pedestrian and snapped his arm off and his elbow got caught between the engine and firewall
Old Oct 8, 2004 | 02:23 PM
scrimbaby's Avatar
scrimbaby
I had another ? if you can't see it then how in the heck are you supposed to replace it. It would really help if I knew what this elbow thing is called because in the chilton book it doesn't have a elbow thing. I might be able to find it if I know what it is called. Could it be called the vwv hose?
Old Oct 8, 2004 | 04:57 PM
homer4.2's Avatar
homer4.2
TOM you're back! I thought I would never see you around here again!!! I hope your here as an "everydayer" like you used to be.. Why aren't you on MSN messenger anymore? did you get a new address or somethin??
Old Oct 12, 2004 | 07:36 AM
Busa01's Avatar
Busa01
Homer, still on instant messenger with the same address, no change.
Tom
94
vette
hotmail
dot
com
The same. I'm back for good now. I was just busy with work and settling into my house...very stressful.
Old Oct 12, 2004 | 08:57 PM
  #28
homer4.2's Avatar
homer4.2
Yep, I understand guy.. Glad to have you back around though..you help out alot in here!!
Old Oct 14, 2004 | 08:53 AM
  #29
Busa01's Avatar
Busa01
Mjeff,
What's the latest stat? Are you still having problems? If you really can't figure out what it is and you ARE throwing codes, I'd take it to a dealer. My truck detonates (pings) at high rpms with wide open throttle. No codes thrown. I've checked every thing there is to check and even have a 6 page thread on this site from a few months back. Other than that, the truck runs fine. I still never did find out what the problem is and it still exists. So I just don't full throttle it and if I hear it ping, I let off the gas. Sooner or later, the problem is bound to rear its ugly head.
Yesterday, I did notice that my rear exhaust manifold bold had broken off and I believe there is an exhaust leak between the motor and the header. I'm not sure if escaping gas at high rpms can cause a lean running condition but I just brought it into the dealer so they can remove the broken off bolt inside the motor and thread in a new one. Who knows, maybe I'll get lucky and that will fix my problem. Got my fingers crossed
Tom
Old Oct 16, 2004 | 08:47 PM
  #30
chipperfan's Avatar
chipperfan
my truck did the same thing it turned out to be a vaccum line. when it did it again i changed the plugs and wires was running fine
