Bell housing leak
Hi Steve..
It seems that more than a few 03's and 04's "alike" have had Rear Main leaks.. Mine leaked from about 200 miles, (1/03 build) and has had 3 replacements.. "DRY" for now!! (4800 miles) First replacement seeped "some" from the RM seal, but Ford had pulled the Rear Engine Cover as a "precaution" for a complete fix, or "just in case" and replaced/re-sealed the cover gasket seal, and it ended up leaking at a later point/replacement. It did leak again though, but it wasn't from the RM seal.. I looked topside to see if anything was leaking, but all was fine.. The leak was actually coming from the "replacement" engine cover gasket and was collecting oil on the nose of the starter then traveling on down the right of the bellhousing.. If they had just installed a new seal, (or two) it probably wouldn't have needed as many seal attemps.. The problem, according to some techs, was that the original seals weren't probably installed straight at the factory.. Our tech, said mine was in correclty but still leaked.. Or maybe it's just design.. The replacement seals, and later engine builds, have a wear sleeve incorperated in the assy, and "may" be a better seal, and do seem to have less leaks.. Who knows, but some forum members have had a fix or two with no improvement, others with success.. There are other possibilities for a leak that can appear as a RM leak.. Have it checked out.. Make sure your servicing dealer has a good diesel tech..
Originally Posted by 'Ol Timer
My 2003 F350 ,build date jan 03, has leaked oil from day one. Dealer is aware of the problem, dye in the oil etc, but I haven't pressed them to fix it yet because of the down time. Wondering how long the dealer typically takes to fix the rear main seal?
BUM F$#% NO FORD DEALERVILLE with the family and a trailer full of angus? WAY to many indentical problems are happening with these vehicles, FORD should be able to fix them since there are so many to work on. This is really starting to SUCK, John
Has anyone had any success with the dealer fixes to the oil leak? Mine has been leaking since new(bought it nov 03). I took it to the dealer for an oil change at 3000 miles and showed them the leak. They said it was assembly lube and it would stop soon. I now have 8000 miles on my truck and "assembly lube" all over my new driveway.
Originally Posted by SBV45
I have had the RMS replaced twice. So far, so good. It took about four hours. If they told you day and a half, they are hedging their bet incase they find it is not the RMS.
Here is what I've discovered. I installed a Autometer oil pressure gage after discovering that the stock oil pressure gage reads in the middle when above 7 psi and 0 below 7psi.
When I started the engine I discovered that with cold 15W40 Motorcraft, I had 90 PSI at idle. When I drove it the pressure jumped off the gage, in excess of 120 PSI. Any old timer truck mechanic like me will tell you that pressure in excess of 90 psi will blow past any main seal and eventually work on the gaskets too.
I changed my oil to 5W40 Mibil Delvac 1 (same as Mobil 1 Truck/SUV oil at Walmart) and the pressure dropped to 70 cold idle and 100 at 2200 RPM cold.
I now try to warm up before I drive off.
All this and the bell housing is slightly wet. No drips on the drive. 14,000 miles.
