Dash Lights
Old May 8, 2004 | 02:38 PM
paulfordf150's Avatar
paulfordf150
Lightbulb Dash Lights
I HAVE A 1994 FORD F150, THE DASHLIGHTS ARE OUT AND THE HORN DOES'NT WORK . ONE DAY THEY WERE FINE AND THE NEXT DAY OUT, I HAVE REPLACED FUSES AND STILL DOES'NT WORK ARE THERE BULBS FOR THIS? THANKS ANY INFO WILL HELP. sweets_1969@hotmail.com
Old May 8, 2004 | 10:03 PM
94fordlover's Avatar
94fordlover
lights and horn
In the cab next to your left leg is a fuse panel. Open it and find the fuse for the dash lights. Its listed on the back of the panel door you take off. Check to make sure you replaced more then one, usually more then one fuse for the dash. If need be replace all. If that doesnt work, you may need a cluster for ur truck. There about 100 bucks and wicked easy to change. I my self just had mine apart. For the horn, open the hood and look under the battery. There are 2 horns. Take off the connectors, hope u have small hands. Take a brush and clean the metal connectors. My horns did not work and it was just corrosion on the metal piece. Replace fuse and clean horn ends and they should work. I too have a 94 =)
xjcamaro89
WTB - Parts & other
Aug 10, 2016 07:21 AM
lildobr
16
Oct 27, 2011 01:54 PM
JEAG
Sep 17, 2008 11:05 AM
88' F-150 4X4
Feb 18, 2007 10:44 AM
roy l sherman
Electrical Systems/Wiring
Sep 21, 2006 01:23 PM
