starting problems
Old Feb 24, 2002 | 08:17 PM
fordtruckluver's Avatar
fordtruckluver
starting problems
I have a 84 F-250 witha 6.9 I am having trouble starting it . I put new glow plugs in it , it started great for about 2 weeks in 30 degree weather it started without being plugged in. It caught me one cold morning at work and would not start, a guy at work told me to use starting fluid. It started and since then it will not start without the starting fluid or being plugged up even in 60 degree weather . Please help this is my first diesel and i am still learning
Old Mar 3, 2002 | 02:15 AM
msta999's Avatar
msta999
starting problems
NEVER, NEVER, NEVER USE STARTING FLUID IN ONE OF "THESE" DIESELS.
If you have to use WD 40. Starting fluid will blow the ends off your glow plugs, then you have little pieces of element going through your cylinders. as a rule if you have to replace 4 or more glow plugs replace the controler too. If the glow plug controler is faulty it will burn out your glow plus "fast". That is what it sounds like is happening here. When removing your glow plugs, best to have the engine atleast a little warm by plugging it in. When installing new glow plugs you can put just a "little" anti-sieze on the threads to keep them from sticking, for easier replacement later if needed.
Old Apr 5, 2002 | 06:15 PM
genericbilly's Avatar
genericbilly
starting problems
I have a 1984 6.9, replace the temp sensor on the back of the intake, i did mine and the glow plugs and she starts like new...good luck
Old Apr 10, 2002 | 08:07 PM
wolfmanagh's Avatar
wolfmanagh
starting problems
I've used starting fluid on these and never blown any plugs.
I also un plug the relay or make sure they are done cycling before using stating fluid.
Old Apr 12, 2002 | 12:33 AM
TKONO's Avatar
TKONO
starting problems
Ed's 95 7.3
26
Jan 26, 2013 06:37 PM
sammydiesel13
Oct 2, 2012 09:24 PM
DarrinPA
Sep 14, 2011 08:57 PM
93turbo7.3
Dec 25, 2010 05:08 AM
jfralph
Jan 13, 2004 10:49 AM
