Offroad & 4x4
lighting
Old May 7, 2004 | 03:24 PM
wyo0713's Avatar
wyo0713
lighting
i am going to get a westin push bar installed on my 1991 f150. i was interested in getting some extra lights that mount directly to the bar. i was wondering how hard it is to get the wiring hooked up for them? and does the switch that is inside the cab require drilling? thanks for the help
Old May 8, 2004 | 12:43 AM
ivanribic's Avatar
ivanribic
Wiring for extra lights is very simple but be sure you use a relay. The lights you buy will most likely come with one, if not then any auto parts store will sell a headlight relay for $5 or so. It will have a diagram of how to wire them. You may have to drill but it all depends on the kind of switch you use. Some switches use a bracket that mounts under your dash (I know KC uses these) and requires no drilling if you can find a screw down there to use. Otherwise you'll probably be looking at putting some sort of hold in your dash.
One last thing, if the wiring diagram doesn't cover this. Run power to your new switch off of your existing lighting system (i.e. splice into a park light). This will shut your auxilary lights off automatically when you turn your headlights off. Otherwise you'll pull an Ivan and forget those damn things all the time which means LOTS of jump starts. Took me quite a while to figure out that trick.
Old May 10, 2004 | 03:39 PM
wyo0713's Avatar
wyo0713
about how much damage will happen if i do have to drill my dash for the wire?
Old May 10, 2004 | 04:07 PM
ivanribic's Avatar
ivanribic
Why would drilling your dash "damage" anything? Just make sure you have your bit set and that there's nothing behind it. If all else fails and you're not comfortable with it then take your truck to a shop to install the lights. There's really not much to them at all.
Old May 10, 2004 | 04:33 PM
95-F-350-4x4's Avatar
95-F-350-4x4
If your worried about drilling you can always go with the ghetto way and use double stick tape!
Old May 11, 2004 | 12:25 AM
rebocardo's Avatar
rebocardo
Being a 1991, foglamps might have been an option. What I have done with adding dash switches (even if the switch was being used for something else) is order a rear window defogger, fog lamp, power moon roof, etc. switch and then use that for the item I wanted to power. That way it fits into an empty unused factory bezel, looks nice, and is easy to hook up and source for a plugNplay replacement later on.
