73-79 shortbed differences?
Old May 7, 2004 | 10:15 AM
ethomps's Avatar
ethomps
Am looking to replace the complete shortbed on my 1977 F150 Ranger 4x4.
Are all 73-79 ford shortbeds the same? Are there any differences that I need to be aware of?
My truck is a SWB, regular cab. Is an extended cab shortbed the same box?
Are the pre-73 boxes the same?
Am trying to figure out what my options are.
Thanks all. Eric
Old May 7, 2004 | 10:25 AM
F150daniel's Avatar
F150daniel
73-76 had gas caps
77-79 had gas doors
some or all 73 had 68-72 taillights.
some beds may have the mounting holes wider or narrower a part.
69-72 are very different.
"My truck is a SWB, regular cab. Is an extended cab shortbed the same box?" yes.
Old May 7, 2004 | 05:49 PM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
Well said ,also the top edge of the bedside is flat you could lay a drink cup
on the flat side (73-79) and the older ones the same area is sloped at about
45° ,also I came across a stepside bed that had the inter rear fenderwells in the
bedside that bolted in most others ive saw were made to the bedside. might
be something to look for if you have tire to bed issues they seem wider than the
others and if there not wide enough you could unbolt them and band them
wider!
Old May 7, 2004 | 06:32 PM
Monster 78 F-150 4X4's Avatar
stepside beds were the same from 53 to 79 some of the earlier stepsider (53 to 76 or 77 had slanted tops)
Old Jun 17, 2004 | 09:40 AM
headleyj's Avatar
headleyj
shortbed bedsides - sim question
Gents,
Been a major fan of the 73-79 style since I was 15 or so. First truck was a 78 SB and still have it and looking to "build a bed" for it. I have 2 good outer bedsides for it, but wanting to put them on another bed, pre 77 that has good inner bedsides, floor etc. I thought the main difference in 73-76 vs 77-79 was the outer left bedside only. If I'm reading this thread correctly the actual bolt pattern can be different? Any explaination/ clarification is greatly appreciated. Thanks!
Josh
Old Jun 18, 2004 | 11:22 AM
Craigwell's Avatar
Craigwell
the highboy 4x4's (73 to 77.5 F250 4x4's) had a narrower frame from the cab back than the f150's or post 77.5 f250 4x4's.
this would affect the mounting holes.
Old Jun 18, 2004 | 11:32 AM
headleyj's Avatar
headleyj
excluding the highboys....I should be able to take any 73-79 shortbed and bolt it onto any other 73-79 shortbed frame, correct?
Old Jun 18, 2004 | 02:17 PM
Craigwell's Avatar
Craigwell
you got it.. if in doubt, a quick check of the frame will tell you everything. it will either spread out behind the cab a few inches or, in the case of a highboy, it will not.
The ladder frame they use stays the same width front to back.
it's as simple as that
PRUSue
Nov 15, 2015 10:05 PM
mofoco1
Apr 24, 2014 11:05 AM
gymbo88
2004 - 2008 F150
Feb 1, 2011 05:27 AM
Ryank78shortbed
23
Jan 27, 2011 08:08 PM
Dads79
21
Sep 27, 2006 07:29 AM
