Sponsored by: Kumho
Extended Radius Arms
Old May 7, 2004 | 12:57 AM
94BlackF150's Avatar
94BlackF150
Does anyone have a set of extended radius arms on there ford 2wd? If you do let me know what kind and if they are any good. Whats the best to get???
Old May 7, 2004 | 01:11 AM
threefiftyone's Avatar
threefiftyone
Email the guy at the bottom of this page. It might help
http://www.autofab.com/87-96.htm
Old May 7, 2004 | 09:16 AM
MustangGT221's Avatar
MustangGT221
Those arn't really great radius arms, mine are 15" longer than stock. You can't use longer radius arms on a non-lifted vehicle.
Old May 7, 2004 | 12:03 PM
94BlackF150
Yeah I looked at those ones that he posted and thats not really what I am looking for. What kind of radius arms do you have on your Mustang??
Old May 7, 2004 | 12:19 PM
BLK94F150's Avatar
BLK94F150
Check out Skyjacker. I tend to like them the best for TTB suspensions such as yours. Mustangs don't have radius arms. MustangGT221 is refering to his f150. Other companies that make extended rad arms include Superlift, Rancho, and Fabtech to name a few.
Mike
Old May 7, 2004 | 12:46 PM
threefiftyone
Hang on, 94BlackF150, Is your truck lifted or not?
Old May 7, 2004 | 02:16 PM
94BlackF150
yeah its got a 6" lift on it with stock radius arms. I have actually snapped four of the radius arms. I dont know if its from the tires rubbing on them or what.
Old May 7, 2004 | 02:18 PM
94BlackF150
Yeah I know mustangs dont have radius arms blkf150. I was asking Mustang what type of extended radius arms he had on his.
Old May 8, 2004 | 10:13 AM
MustangGT221
I have the skyjacker radius arms, and you won't snap a radius arm by the tires rubbing. The only time I ever bent a radius arm was in a car accident. You broke four? You are talking about the bar that goes from the suspension arm to a bracket on the frame almost under the door right? Since you have a lift, you can get them. Also, please use the edit button to add/change something in your posts rather than making a 2nd post.
Old May 8, 2004 | 02:16 PM
94BlackF150
I know what a radius arm is and I know that I broke four of them. There is a spot on the radius arm that is very shining therefore is from the tires rubbing in a certain spot when you turn. I am reall led to believe that when turning sharply the tires rub on the arms and weaken the radius arm. I have no idea what else it could possibly be. Do you have stock radius arm mounts or are they the drop ones with the extended radius arms. Also do you have stock radius arm bushings. I heard those were the best because they allowed a lot more flexibilty then the aftermarket ones.
Old May 8, 2004 | 04:47 PM
mrwizard's Avatar
mrwizard
Unless you're running carbide-tipped tread on your tires, the rubbing won't damage the actual arm itself. All it's going to do is keep that one spot nice and shiny-clean.
Old May 8, 2004 | 06:06 PM
william_ace's Avatar
william_ace
i've got extended radius arms on my truck, just check out my gallery. i got mine from AIM industries, they help out with stability, but still rub a little bit.
Old May 9, 2004 | 12:21 PM
MustangGT221
I have the skyjacker extended radius arms with poly bushings that came with my lift kit. Mine still rub, it's almost inevitable w/ wide tires. It doesn't weaken the arm at all, its just rubber rubbing metal...how does that weaken it? All it does is rub the paint off.
94xlt150
Mar 9, 2015 06:51 PM
AvdDrift
Dec 18, 2014 10:04 AM
Backflip164
Dec 2, 2014 02:45 PM
Nickk97tml
Jan 12, 2014 07:41 PM
balingwire
Sep 19, 2013 10:46 AM
