front end swap
Old May 7, 2004 | 12:08 AM
FATPAULJ's Avatar
FATPAULJ
Question front end swap
Hi i need some help i have a 1966 f-100 and i want to put power steering and disk breaks on will the front end off a 1974 1\2 ton fit or are they a diffrent demension
fatpaulj
Old May 7, 2004 | 12:13 AM
camperspecial65's Avatar
camperspecial65
Hello, From my understanding on the D/B conversion, the wheels I think will need to be updated due to caliper clearance issues with original wheels. As to the I Beams, etc, I am most positive its a direct bolt in....the only area I am vague on is the steering box....does your 66 have a P/S box in it now or Manual box? also, which engine....6 or 8 cyl.
Im sure others will chime in on this as its a popular change....BTW, is your kingpins okay or not....my 66 1/2 ton is in need of a bit of help in that dept.
Hope this helps, camperspecial65
Old May 7, 2004 | 12:20 AM
FATPAULJ's Avatar
FATPAULJ
no every thing is manual no power anything and it has a 6 cyl for now but is gettin a rebullt 429 later down the road after some more work gets done
as for the kingpins they are in great shape.
fatpaulj
Old May 7, 2004 | 05:23 AM
jowilker's Avatar
jowilker
Paul, Everything is a boltup exchange. You may need to use the drivers side engine perch if the donor has a 360 or I6 like your truck to keep the head of the steering gear from hitting.
John
Old May 7, 2004 | 05:25 AM
ddavidv's Avatar
ddavidv
'74 is an acceptable donor. Do some searching on here for the power steering as there are a lot of things to consider when it comes to the steering columns as the shaft length is different.
The disc brake swap is addressed here on my web site.
Old May 7, 2004 | 11:04 PM
66fdtrucknut's Avatar
66fdtrucknut
Excellent info. on your website ddavidv. I need to do it to my 66' 250.
Ikestang
13
Aug 3, 2017 09:33 PM
53FOPAR
Feb 6, 2017 08:42 PM
kevintoupin
Sep 15, 2016 10:05 PM
mdayz28
Apr 30, 2016 11:51 PM
grams72
Aug 12, 2010 09:28 PM
