alternator specifications needed
Old Jun 14, 2000 | 05:34 PM
newtruck's Avatar
newtruck
Dual alternator specifications for a 2000 f350 with a 7.3 PSD. Thanks....Richard
Old Jun 29, 2000 | 09:03 PM
ExcursionPSD's Avatar
ExcursionPSD
Ford dual alternators on Power Stroke Diesel each put out 110 amps (probably at 1500 to 2000 rpm) the second alternator is mounted down low and to the passenger side. It is driven by a serpentine belt that is longer than the standard belt. This option is not available on Excursions.
2000 Excursion Limited born 11/99 4x4 Toreador Red ext./gray int. 7.3PSD, 3.73LS, Skidplates, Pwr/Htd TeleMirrors, 6CDchanger, HtdBuckets, LT265/75R16C AT, Ford Wraparound deflector, PSDV8 badging, RoofMarkerLights
Old Jul 24, 2000 | 12:39 PM
ExcursionPSD
For completeness sake, I want to add that the 2001 ordering guides indicate that the PSD alternators are now 115 amp. I do not know if this is a change in the alternatore itself, or just a change in the rating.
2000 Excursion Limited born 11/99 4x4 Toreador Red ext./gray int. 7.3PSD, 3.73LS, Skidplates, Pwr/Htd TeleMirrors, 6CDchanger, HtdBuckets, LT265/75R16D AT, Ford Wraparound deflector, PSDV8 badging, RoofMarkerLights
Old Apr 21, 2002 | 07:33 AM
Super_Dave's Avatar
Super_Dave
Does one alternator charge one battery, and the other, well, charge the other?
I'd like to set up two seperate batteries to power an inverter inside my machine. So, would putting an isolator on one of the alternators to divide up some power to keep the two deep cycle batteries up while driving work?
Any thoughts would be appreciated.
Old Apr 21, 2002 | 03:32 PM
hunter3611's Avatar
hunter3611
Deluxe06
Mar 9, 2013 02:48 PM
DarkStarMedia
Apr 4, 2012 10:38 AM
SurpriseF350Sport
Nov 24, 2009 07:17 PM
richard_d
Electrical Systems/Wiring
Oct 27, 2001 08:35 PM
RICHARD
1997 - 2003 F150
Feb 27, 2000 03:07 PM
