How much "cooling value" from remote oil filter?
Old May 6, 2004 | 03:52 PM
Old Blue Crew's Avatar
Old Blue Crew
Has anyone ever figured out how much an engine's oil is cooled by running a remote filter? How about a dual filter set-up? I am planning on running a remote filter mainly for the ease of changing them, but figured any oil cooling I get out of it is a bonus.
Old May 6, 2004 | 04:02 PM
rusty70f100's Avatar
rusty70f100
If you want the oil to run cooler, just throw in a lower temperature thermostat. The engine will run cooler, and the oil will run proportionally cooler. Dont go below 180F though, since your cylinder bore wear goes up.
Why do you want it to run cooler? The zinc anti wear additive doesn't work best until the oil is good and hot, and having the oil hot evaporates water out faster.
If you're towing and running the engine at WOT all the time then you might look into an oil cooler.
How much does it cool the oil to have a remote filter? Probably not enough to measure. The dual filters would have more surface area, so they might run it a *little* cooler.
Old May 6, 2004 | 04:36 PM
Mike G's Avatar
Mike G
I haven't given any credit to the oil cooling by using the remote filters, it really just makes life a little easier (and cleaner).
--Mike
Old May 6, 2004 | 11:47 PM
robduval's Avatar
robduval
where are you mounting the oil filters? if your monting them under the hood you more than likely won't see any change in the oil temp.
Old May 7, 2004 | 01:38 AM
gt6plus's Avatar
gt6plus
Remote oil filters used in conjunction with an oil cooler, that would help.
the_auto_tech
Oct 13, 2013 09:33 PM
lakedweller
6.7L Power Stroke Diesel
148
Jul 16, 2012 04:24 PM
ralf12
Sep 16, 2010 08:28 PM
Hawkeye77
1997 - 2003 F150
Mar 15, 2005 03:51 PM
