Sway Bars
Thanks
What I did and may be an option for you also is after installing the Heidts Superide on my 55 I walked under numerous vehicles that were up on hoists(I work at a dealership) and took measurements.
I wanted a big diameter bar so I ended up using one for a 1997 Expedition 4x4.
At that time they were only about $45-$50 and I bought the appropriate end links and bushing kits from Jegs.
It did require some minor modifications and I fabricated the link mount on the lower control arm, but you may find something that will bolt right on to your application.
Its for a mid-50's Chebby, I want to see if it can be adapted to my 48 F1.
And 4tl8ford, I appriciate your keying me in on the article, it will be in my hands shortly
In the past I've made sway bars for small SCCA race cars (mostly F-Production "Spridgets") and the process isn't too dificult - but I have no engineering data to take any of the trail and error out. There is a good article at Grassroots Motorsports web sight (www.grmotorsports.com) that details some of the design variables and also some of the adjustment features that are good to build in and you may find that helpful.
The last bar I built was for a rear straight axle and -since we didn't know how stiff it had to be - we used a solid bar and made it too big from the beginning and then took it to the lathe and cut the center section down until we got it right. Final (and tuning) adjustment was via different holes in the control arm attached to the splines at each end that effectively changed the length of the arm and consequently the stiffness of the bar. Just be careful as too stiff an arm (front or rear) can really make for some "unique" (scary) handling untill you get it right. If you have access to a skid pad (big parking lot after hours with no light poles in bad places) it can be very helpful and much safer to dial it in.
Leaks
Where's the fun in the parking lot.
It shold be done on a residential street, with both curbs lined with expensive cars.
4tl8ford...regards residential street with expensive cars...VERRRRRRY NICE! Unfortunately my pocketbook won't allow for such excess but it's a wonderful daydream!!! Fun! Bent BMWs, Porsches and Mercedes and probabaly not more than a tiny dent on any of our trucks still running a real steel bumper! Might be frowned on by the local constables though....oft times there is little sense of humor about such things...Thanks for the chuckle!
Leaks
I have not really contacted many vendors as I usually just get more questions than answers, but I will definityly give No Limit a call. At the very least it seems that I could modify or make a new bar and grass roots motorsports looks like a good resource.
Thanks for the help guys, I am glad to hear what is availiable.
Benny
If you can walk through the local yards with a tape measure, I think you will find something that will work. A sway bar is one of the few things that only has to be close to correct to offer considerable improvement. Anything that inhibits body lean will be of benefit.
