Slave Cylinder Line
Old May 5, 2004 | 08:05 PM
BEARBQ's Avatar
BEARBQ
Slave Cylinder Line
I've Got A 1994 Ford Ranger With The Small 4cyl. Engine And 5speed Standard Tranny. I Can't Get The Slave Cyl. Line At The Tranny To Disconnect, Help Anybody. Thank You Da Bearbq
Old May 8, 2004 | 12:41 AM
24t's Avatar
24t
there should be if im thinking right a little plastic or metal ring on that line that you push in toward the transmission while wiggle-in it loose
Old May 10, 2004 | 10:48 AM
BEARBQ's Avatar
BEARBQ
Smile Slave Cylinder
Thank You 24t For Your Reply. I Was Advised That Same Thing But Someone Must Have Broken It Off. I'm Still Triing To Figure Out How To Seperate The Two Parts. Thanks Again . Bearbq
