Tranny question.
Old Apr 27, 2004 | 09:50 PM
91 xlt lariat's Avatar
91 xlt lariat
Tranny question.
I have a 1991 F250 Lariat with the stock automatic transmission in it. I dont know what tranny or much about it either, just my hauling truck.
My question is: Its been doing this weird shifting/not shifting thing. I will put it into drive and start to go, then it wont shift into 2nd but will continue to rev untill its out of gear (25mph). If I take it out of drive and put it into 2nd it will go right into second no problem, but when put back into drive it drops into 1st.
Anyone know what might be causing this, my guess right now is the tranny fluid??? I really have no idea what is going on, neither does the mechanic that we took it to.
Old May 10, 2004 | 12:08 AM
Kikr's Avatar
Kikr
I have the same problem on my '90 f-150. Have looked and asked everwhere and nobody has an answer. Shifts fine for months, then for a few days... SLAMS into gear! Then it clears up.
Old May 10, 2004 | 11:26 AM
blackthorne2's Avatar
blackthorne2
This is a recall from Ford from back in 1991
ATRATB057
A/T - Delayed Engagement In Reverse & Drive
TRANSMISSION: E4OD
BULLETIN: # 057
SUBJECT: Delayed Engagement
APPLICATION: Ford
DATE: July 1991
Delayed Engagement in Reverse & Drive
Step 1
Make sure line pressure isn't too low. Line pressure at an idle should be 74-100 psi in reverse and 55-65 in drive.
Step 2
Remove the engagement control valve spring.
THis is something I have not followed up on with my truck as it bangs into gear once ina while when shifting into reverse or drive. It may be a contributing factor to your probelm. I let you know if mine is still in and what happens if I take it out.
Old May 10, 2004 | 11:33 AM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Did you check for codes?
91 you could have a bad TPS that would act sorta like this, don't just go out and buy one though.
Kikr, yours may be a MLPS sensor. Don't just go out and buy one though.
There is a tech guide available at transmission parts houses for about $15 that gives troubleshooting info.
It never hurts to change the fluid and filter, if you do it right. And if you see chunks of metal or clutch plates in the pan, you know you have more serious problems.
There is a transmission forum here at ford-trucks, you may want to search and read there some and maybe ask them.
