Headlamps Wont Come on
Hi,
My 1996 ford explorer is having some major lighting issues. The headlamps won't come on! When i turn the swith, the yellow lights next to the head lamps come on, and the turn signals work. Also, the rear lamps come on. The bulbs are good cause the brights work, but the normal headlamps and fog lamps won't light? Any suggestions? please???
Thanks,
Thanks,
Well first off just because the high beams work, doesnt necessarily mean the low beams are good. They are on separate circuits. The low beam element can burn up and the high beam element be just fine. However I doubt that is your issue. You could have an assortment of problems from fuses, headlamp switch, multifunction switch, and if you have an Eddie Bauer with the message center in the center console it could be a bad Lamps Out Module. Could be bad bulbs though, or a combination of any of the above.
I'm having the same problem
Gemini19th81 -- I have a 1998 F-150 and I'm having exactly the same problem you described. Mine started about 10 days ago. The first time it happened, my headlights and fog lamps didn't come on when I started the truck (I have the autolamp feature), but as I backed out of my garage, they came on. The next time I started the truck, I couldn't get them to come on at all. But just like yours, the parking lights, tail lights, brake lights, and turn signals work. And when I pull back for flash-to-pass, the high-beams work. I've checked all of my fuses and they're fine. Did you figure out what was wrong with your Explorer? Thanks.
brokersteve
01-16-2017 11:39 AM
troverman
1999 to 2016 Super Duty
48
08-21-2016 10:32 PM
Comanche1Star
03-15-2014 09:03 AM
7636074460
03-12-2014 08:59 AM
King Kerosin
07-19-2013 08:56 PM
