750CFM vs 600CFM
Old May 7, 2004 | 02:03 PM
bremen242's Avatar
bremen242
Probably not enough to notice.. maybe 20ft/lbs.
Old May 8, 2004 | 12:21 AM
DanMartin's Avatar
DanMartin
Clifford,
I got it from Summit Racing (www.summitracing.com).
Heck, I jus happened to have the receipt here! The part numbers were:
ATM-2244 (O2 sensor kit)
ATM-3375 (Gauge)
I also bought two other gauges at the same time, and a 3-gauge mounting bracket:
ATM-2238 (Bracket)
ATM-3301 (Vacuum Gauge)
ATM-3351 (Trans Temp Gauge).
Hope that helps...
Dan
Old May 8, 2004 | 09:23 AM
melisa's Avatar
melisa
I put a 750 edlebrock carb and performer intake on my 460 dually, and I gained low end power. Especially noticable on mine, since I have the 3.55 geared rearend. i have spent some time tinkering with it, and it keeps getting better, getting about 10mpg now towing or not. Has enough power now to tow my 5000 lbs empty horse trailer, and if I punch it, the horses have to hold on!!!
Old May 8, 2004 | 09:31 AM
oldhalftons's Avatar
oldhalftons
i put a 750cfm holley 3310 on my 460 and it gets better mileage then it did with the OEM 4180
It REALLY woke the truck up. its running 64 primary jets and 66 secondary jets
gained low end, gained high end, lost nothing.
Old May 8, 2004 | 03:41 PM
fordeverpower's Avatar
fordeverpower
doesn't take much to outperform an emissions 4180 carb.
brian eiland
43
Mar 3, 2016 07:06 PM
lewistg
Jan 15, 2016 05:21 AM
tragicsandwich
Feb 19, 2015 06:52 AM
Golden210
Jan 20, 2015 06:44 PM
TheDesertRat
Oct 3, 2011 12:14 PM
