6.9l Glow Plugs
Old May 6, 2002 | 01:15 PM
The Diesel Dude's Avatar
The Diesel Dude
6.9l Glow Plugs
Old May 6, 2002 | 06:09 PM
wwbuzzard's Avatar
wwbuzzard
6.9l Glow Plugs
Who makes the best glow plugs for the early 6.9l engine.
I have been told that there are single coil and dual coil
glow plugs and some plugs are 10 volts while others are 16
volts. Is this correct? Please include part# if you can. I will
be replacing the glow plug controller at the back of the engine
with a used one. If the replacment fails how do you wire in a
push button or toggle switch to activate cycling?
I will run the plugs manually since the controller is $200.00 canadian. :x
Thank you.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
