I own a 94.5 psd f450 superduty dually.Iwas wondering if somebody can tell me what these numbers and letters mean on the inside of my door post,they are as follows.
WB 161
type GVW F477
body C68
trans C
Axel 73
springs H48
GVWR 15,000lbs
A few of them I can help with:
WB 161 161" wheelbase
type GVW F477
body C68
trans C
Axel 73 non-limited slip 5.13:1 gear ratio
springs H48
GVWR 15,000lbs GVWR 15,000lbs. I guess you had that one figured out, eh?
Thanks for your reply Quadzilla.In regards to the axel non-limited slip does this mean it is a full posi and 5.13:1 is this a low gearing or what is it compareable to.
It' s not a posi rear end. the 5.13 gears are quite low. I assume you've got a fairly high rpm/speed ratio. With my 4.10's, at 70mph, I'm turning 2000rpms. I imagine you're turning quite a few more rpms at 70mph than that.
Thanks for your reply Quadzilla.I'm turning 2500-2800 rpms at 70 mph and the tach. starts into the yellow line at 3000rpm so I do not usually run that speed to often.What would the advantage be of running such low gears and would this make it harder on fuel than others.
