What does this fit?
Old May 4, 2004 | 03:38 PM
zwinstead's Avatar
zwinstead
What does this fit?
Help... I have researched the threads on the site for info regarding flywheels. I have a flywheel part# D7TE-6380-D (G or 6). A guy said this came off of a 351M/400 but Bubba's M-Block page does not list this part# as a viable option for the M engine??? Any ideas? I need a flywheel for a 400 running a 12 inch clutch.
Thanks
Zac
Old May 6, 2004 | 02:53 PM
Nev. Bronco's Avatar
Nev. Bronco
Napa was real helpful in setting me up with a 12" HD diaphram set/kit. Originally I had or have the 11" hole pattern and some other holes that werent tapped. Napa looked up the measurements and stated they had the parts and I took the flywheel with me and got the whole kit. Sorry cannt remember which way they got the measurements but it was 2 hole to hole sets they needed. They also stated that the bolt pattern also matched a chevy 12" p/plate. This is the kicker, Ford rounds the edge of the p/plates and to get the width for a 11" or 12" ford p/plate with go wider. Napas was a diff design more squared so as to not go wider to get the 12" Diaphram. I installed this in my 79 bronco and it clutches easier then a hydrolic (sp) system but is a HD set up. Take your plate to a Napa and they can spec it for you.
scolberg
Jun 8, 2016 11:14 PM
Colt.S.
Sep 22, 2015 11:41 AM
hellraiser
Jan 12, 2004 02:14 PM
greg2560
Jun 6, 2003 09:01 PM
jeff03
Sep 2, 2001 07:51 AM
