Ungodly clatter
Old May 4, 2004 | 01:28 PM
Boise_Chief's Avatar
Boise_Chief
Ungodly clatter
I have a 92 f250 D 7.3l Yesterday I developed a nasty clatter on startup. It sounds like a piece of metal vibrating against metal. Much clearer than lifter noise, I have no loss of power no smoking no rough idle. I seems to run fine but occasionaly it starts clacking. If I don't clatter on startup it won't make any noise until the next time I start it. It doesn't seem to be in the clutch, clutch opperation doesn't change it. any Ideas on what to check. I changed the oil and fuel filter last week. Could it be too light of a viscosity oil?
I am unfortunately ignorant about diesels and have never heard this kind of a noise on any vehicle I've owned.
Thanks for any help.
Sean
Old May 4, 2004 | 05:13 PM
jadel's Avatar
jadel
Check your exhaust it could be a clamp or a hanger.
Old May 4, 2004 | 05:47 PM
bilder12's Avatar
bilder12
what oil did you put back in it? The best type that I have found is 15W-40 DIESEL oil. You might be experiencing lifter bleed down if the oil is not heavy enough. Keep us posted.
Old May 5, 2004 | 08:03 AM
gbeach's Avatar
gbeach
my 93 7.3 is doing the same thing. it clatters for about 6 seconds on startup. it does not do it all the time. it seems to do it after it is warm and i turn it off and then start up again. it sounds to me like it is not getting enough fuel, because it sounds the same as if you are running out of gas right before you switch tanks. i do not put my foot on the gas when i start it up warm. i am stumped. use 15w-40.
Old May 5, 2004 | 09:27 AM
ditch witch's Avatar
ditch witch
gbeach,
You really using gas? No wonder it's clattering. Probably lots of black smoke also!!
Old May 5, 2004 | 10:47 AM
Spectramac's Avatar
Spectramac
Sounds like a bad dampened flywheel to me.
Old May 5, 2004 | 10:49 AM
equium's Avatar
equium
Originally Posted by ditch witch
gbeach,
Boy, did i ever get that drilled into my head growing up working in a truck yard! "It's FUEL" my boss/brother in law used to yell at me. shook me up so bad, i hardly ever use the "G" word anymore.
Old May 5, 2004 | 05:09 PM
bilder12's Avatar
bilder12
The only gas i get from being around my diesel ride is from the darn burritos.
Old May 5, 2004 | 05:15 PM
equium's Avatar
equium
ROTFLMAO
What was the original problem? Ungodly Clatter? i get that too; it goes away after i drop the wife off at work.
Old May 6, 2004 | 03:17 PM
Boise_Chief
And Spectramac is the Winner!!!
Most likely this is the problem. I am going to pull the starter tommorrow and check for a spring floating around. I pulled the dust cover and didn't find anything. No debris or anything, but the shop down the street said that they sometimes will bounce up inside the bell housing and get stuck. then the noise stops.
Does anyone run a solid flywheel instead of the torsion dampened ones. The price difference is about 800 bucks and if the only problem is increased gear noise I might use the solid one.
About oil I used 10w40 diesel oil don't remember what brand but I don't think I'll use it again.
Old May 6, 2004 | 11:19 PM
FSC's Avatar
FSC
I don't think 10/40w is a diesel oil, my truck forbids the use of 10/40w, I can use almost anything but that.
