Help, 302 overheating...
Old May 3, 2004 | 09:30 PM
rangastang5.0's Avatar
rangastang5.0
Angry Help, 302 overheating...
hi im a new owner of an 87 ranger which has been converted to a 89' mustang 302. the truck drives and runs well but overheats exesively, after chekign the coolant and refilling i noticed that it again seemed to dissapear, after further insepction i noticed a few other odd things about the motor....
1. when running steam comes out of both valve cover vents even when the truck is cold
2. a white buildup is forming on the inside of the valve covers, its not ard an limey like of burnign coolant but has the appearance and consistency of white lithimum grease
3. the truck runs cold for the first 15 min of operation but after temperature climbs extremely rapidly
4. when running hot the engine looses alot of power and begins to idle very roughly
5. if ran long enough steam beging to come out of the exhaust
i think that a headgasket has blown out and coolant is flowing into the oil channels and even seeping into the cylinders but that doesnt explain why steam is flowing equally out of both valve covers, if anyone has any ideas what other things can cause such behavior and what the hell causes the white buildup?
Old May 4, 2004 | 12:10 AM
c96drumm's Avatar
c96drumm
The white stuff is water in the oil. It's probably either a head gasket or intake manifold gasket. Or maybe something with the timing cover. I've had that happen, but not on a Ford. I wouldn't run it any more until that's fixed.
Old May 4, 2004 | 07:48 AM
jroehl's Avatar
jroehl
Sounds like either a head gasket or even a cracked head. It's been my experience over the years that the 302 doesn't like excessive heat....
Jason
Old May 4, 2004 | 07:49 PM
Beast12's Avatar
Beast12
Yep...thats a head gasket.....too bad,....
-Matt
Old May 4, 2004 | 08:28 PM
stevef100s's Avatar
stevef100s
The steam is coming out of both sides, because both sides use the same oil and pan, and are connected by the same crankcase.
Old May 4, 2004 | 09:02 PM
wcm54truck's Avatar
wcm54truck
is it possible your water pump is turning the wrong direction?wcm54truck
Old May 5, 2004 | 10:26 AM
fordberg's Avatar
fordberg
If you do a rebuild, get the heads and block magna-fluxed. This will check for cracks. Many times the head gaskets are replaced but a head or the block is cracked. Also get the heads milled to make them flat. Mag-fluxing during a rebuild might cost $100 so it could be very worth while.
Old May 5, 2004 | 04:03 PM
rangastang5.0
thanx, im probablyging to end up replacing the heads anyway, the ones currently on there are off a 66' fairline 289 could that be causing the problem?
Old May 5, 2004 | 09:53 PM
wcm54truck's Avatar
wcm54truck
all you can do is pull heads and check matchup of water holes.i just thought id mention water pump rotation.a lot of guys dont know fords go both ways
