Sponsored by: Real Truck
Need Help with Rearend !!!!
Old May 3, 2004 | 08:15 PM
8URHEMI's Avatar
8URHEMI
Not that rear end, I can hear it now. Anyways, My rear diff. is leaking fluid ( a lot ) I found out it is comming from the area where the driveshaft goes into the diff. front. Is that a bering or seal, and whats its correct name so I can get one.
Also, can you hel pme decode the rear to see what I have, on the door sticker it says C3, tag on cover reads 34 21 B -- 41 30 10 --8F24 thanks.
Old May 3, 2004 | 08:33 PM
FortyFords's Avatar
FortyFords
Thats the pinion seal ,you have a Ls with 4.30 ratio
ls is limited slip ,the 4 (1 is a L ) 30 ratio
The L stands for limited slip
How many miles on the truck ?
I would chk the entire rear out
chk for backlash (play between gear teeth )
chk endplay on pinion shaft
chk runout on flange that the driveshaft attaches to
chk pinion bearing for roughness
chk the rear flange for a groove where the seal rides if it is deep it will leak even if new seal is installed.
Also what I have had in the past is the carrier bearings go bad and cause laterial stress to the pinion bearings. end result was pinion seal leaks alot.
Rich
Old May 3, 2004 | 09:10 PM
8URHEMI's Avatar
8URHEMI
Thanks, I'm going to have it checked out tomorrow. Hopefully just a seal. Odo. says 39,600, but I think its been changed, most likely 80000 miles.
