Removing the Tow-Hooks
Old May 3, 2004 | 07:45 PM
Hoop's Avatar
Hoop
I was thinking about pulling the tow hooks off of the excursion and sanding them down and polishing them... then I'd clear coat them. It's better than paying a couple hundred for stainless hooks.
What is the easiest way to get those damn things off?
Old May 3, 2004 | 08:19 PM
dliguori's Avatar
dliguori
It's a pain in the ***! I just took the bumper off which is easy(it's really light) but then you need an array of wrenches and ratchets in order to get inside the frame and bellow the frame to get the things off. You will need a (I believe it is a 19mm) wrench as well because one of the three bolt on the inside of the frame is so close to the side of the frame that you can't get a ratchet over it. Basically take the bumper off and take the hooks themselves off and then you can get the hook mount off.
Old May 3, 2004 | 09:38 PM
02superstroker's Avatar
02superstroker
Make sure you get those three bolts back in, as they are the front three bolts that hold the spring hanger on!
Old Jun 18, 2008 | 08:39 PM
afinepoint's Avatar
afinepoint
Would removing the front cross member have helped?
Reg
Bruteskeg
Jan 9, 2014 01:26 PM
Bruker
1983 - 2012 Ranger & B-Series
Sep 7, 2009 07:53 AM
Byos
Aug 7, 2009 08:12 AM
ckrichard
2009 - 2014 F150
Jan 7, 2009 04:20 PM
jetmagnum
Jul 6, 2006 02:22 PM
