1966 - 1977 Early Broncos
starting troubles
Old May 3, 2004 | 12:41 PM
Devildragon's Avatar
Devildragon
starting troubles
what's up guys got a problem. I have a 74' 302, it has no problem starting cold but when it get hot it won't start. The starter is nice and strong, I have a good strong spark, battery is good ignition coil is good, when I go to start it when its hot only the starter kicks over the engine won't, I'm leaning towrds the points but I'm not sure if anybody has any info please let me know.
thanks
Cash
Old May 3, 2004 | 11:53 PM
68 351 bronc's Avatar
68 351 bronc
Sounds like a rich condition on the carb side. Or timing. I would start with checking the timing. Then adjust the idel circut screws on the carb.
Old May 4, 2004 | 09:50 AM
Devildragon
thanks I'll give it a shot.
Old May 4, 2004 | 09:13 PM
agtech's Avatar
agtech
timing
I had a 79 with a 302 that did the same ole trick. You definitely have a timing issue. I finally had to put a new chain on mine.
Old May 4, 2004 | 11:04 PM
Devildragon
I'll look inot it but also, whenever I really romp on it, it really dies down, I have a new edlebrock 600cfm performer series carb on it we tried adjusting it, and it ran a little better when it was running richer, could the timing or timing chain still cause this problem? thanks for all you help you guys are great.
Cash
Old May 9, 2004 | 11:01 AM
agtech's Avatar
agtech
I guess I might have thought this over wrong. If it is a timing issue the motor will be hard to crank when it gets hot. Kind of like a dead battery. If it cranks fine but won't start then it might be the carb. As for adjusting it, very few people are good at this and I'm not one of them. I've rebuilt several crabs and only one ran better after I was done. Sorry.
Old May 9, 2004 | 03:20 PM
dk5122's Avatar
dk5122
Do you have another carb laying around? You could switch it out in less than an hour. I would do a complete tune up. Sounds like it might be a combination of things.. Please post back when you figure it out...
Old May 9, 2004 | 03:23 PM
dk5122's Avatar
dk5122
I know a couple of guys who could never get the edlebrocks tuned in right, and they all went back with Holleys. Never had any problems since.
Old May 10, 2004 | 02:44 AM
wyldstallyn73's Avatar
wyldstallyn73
You said that when it's hot that the starter cranks over but not the engine- Thats clearly a starter problem. But maybe I'm just misunderstanding your message. If the engine is turning over, the first thing I'd do is make sure the choke is open when it's hot. other than that, I dont know what to tell you- it could be a lot of things.
Old May 10, 2004 | 10:25 AM
okiebronco's Avatar
okiebronco
if the engine is turning over it could be timing as was mentioned above. more often than not when timing is too far advanced it will turn over hard (like a dead battery) when warm. but for the longest time my bronco would start great when it was cold but when it was warm it would just crank and crank and crank (about 10 or 12 revolutions before it would start. well one day i decided to rebuild the carb and while it did run better it was still hard to start when warm. after that just for giggles i decided to retard the timing a bit and retune the carb to the way the timing was set after i retarded it. now not only does it fire right up when cold it fires up with less than 1 revolution when warm. btw when my timing was too far advanced it would turn over nice and smooth so i didnt REALLY think it was a timing issue although the bronco had to make me a lier out of me
Old May 10, 2004 | 07:12 PM
Devildragon
thanks for all your input guys I really appreciate it, it was a little timing problem and the carb needed adjusting for it to run right but it still wasn't starting good, so I replaced the ingnition coil again and I replaced the ignition wires also, I wasn't gettin very much spark, now its better. WHen I took it to get the carb adjusted the guy had to advance my timing almost all the way, its in the shop right now and I won't be able to pick it up till friday but as soon as I find out what happened with it I will keep you guys posted.
thanks again
Cash
Old May 11, 2004 | 01:53 PM
68 351 bronc
I bought a brand new Edelbrock 600 and it would never start good warm and would die on any kind of an incline. After 2 years of hating it I finally put on a holley and it starts good cold or hot. The Holley will take some tuning to run good under all driving conditions. But I think it's twice the carb that the Edelbrock is.
Old May 11, 2004 | 06:39 PM
dk5122's Avatar
dk5122
I agree, When you get the Holley tuned in it will stay that way.
Old May 14, 2004 | 12:41 PM
Devildragon
hey guys, well I feel like an idiot cuz the guy said that I was driving around with my choke on the whole time, I could've sworn I checked that but I guess not so far thats the only update I can give cuz I haven't picked it up yet, but as soon as I find out more I will let you know. thanks again for all your input.
Cash
Old May 15, 2004 | 05:04 AM
wyldstallyn73
Chalk up a point for the stallyn-BOOOYAA BABY!!!
