alternator wiring
Old May 2, 2004 | 02:47 PM
1983vf750f's Avatar
1983vf750f
alternator wiring
I am currently doing a frame up resto on a 1974 f-250 4wd. I have used the chassis and running gear to include the 360 from the 4wd and I am installing a 1971 sport custom 2wd body. Chassis and motor complete, I have painted the cab inside and out and I am now trying to re-install the wiring. I used the harness from the 1971 2wd with the exception on the motor wiring. Everything pretty much plug right up but I am left with one white wire with a black stripe and nowhere to hook it up. It comes from the alternator where it is stamped (STA) and has a black boot. It ends near the solonoid and has a female connector on it. Any help as to where the wire goes or what it is for would be appreciated. Thanks in advance.
Old May 2, 2004 | 03:11 PM
Fordtech1's Avatar
Fordtech1
Electric choke heater.
Old May 2, 2004 | 04:19 PM
1983vf750f's Avatar
1983vf750f
Thank-you ford tech, that answers my next question. I installed a holly 600 4bbl with electric choke and was wondering where to draw from. Thanks again.
Old May 2, 2004 | 10:20 PM
Franklin2's Avatar
Franklin2
You can try the stator wire on the holley choke, but if you find it's not working very well, you may need to hook a 12 volt wire from the ignition switch to the holley choke. The stator wire supposedly does not put out a full 12 volts.
