General Automotive Discussion
Winch choices
Old May 2, 2004 | 02:41 PM
79_250RangerLariat's Avatar
79_250RangerLariat
Winch choices
Well the time's come to get a winch.. I know the Warn and Ramsey winches are good, has anyone used the Magnum brand winch? I see a lot of them on Ebay and was wondering how durable they are. I'm not looking for something to pull the truck up over a cliff or anything like that. Probably around a 5-8,000 lbs pull for dead tractors and trucks.
Thanks!
Old May 2, 2004 | 06:34 PM
jhemr's Avatar
jhemr
I've heard the magnum is a private label economy Warn.
If you are pulling trucks & tractors I would go at least 9000 or 9500 lbs.
The closer to max pull rate you run, the more amps the motor draws,
and the closer you are to stalling the winch. Figure the max lbs you need
to pull, x 1.5, this should be the min winch size to buy.
Warn is my first choice, Ramsey close behind. Look at the specs of
different winches, they vary a lot, line speed, motor size, gear ratio.
I run a Warn 8000i & synthetic rope on my Jeep, works great.
Just My 2¢
rbloodhound
Offroad & 4x4
Mar 9, 2008 11:22 PM
78 Ranger
Offroad & 4x4
Feb 1, 2008 01:16 PM
RMK
Offroad & 4x4
16
Mar 7, 2007 11:13 AM
78 Ranger
Offroad & 4x4
Aug 4, 2006 10:46 PM
Rob Cuenin
Aftermarket Products
Jul 9, 2005 09:29 AM
