Aerostar Ford Aerostar
Brake question
Old May 2, 2004 | 12:30 PM
shel 67's Avatar
shel 67
Question Brake question
I've noticed on my aerostar recently that there is a vibration felt on my steering wheel when I apply the brakes, especially when going down a hill. I thought it might be a warped brake disk. Any suggestions?
Old May 2, 2004 | 12:43 PM
92nTN's Avatar
92nTN
that is most likely the problem.looks like a brake job is in order!
Old May 2, 2004 | 01:09 PM
xlt4wd90's Avatar
xlt4wd90
SHEL_67,
It does sound like the rotors are getting weak, and warping under heavy use.
What year is your van? The models before 1992 came with straight vent blades in the rotors, which do not work as well as the 1992 and later models with the curved vent blades. However, the later rotors will fit onto the earlier vans. When you order new rotors, you should ask for replacements for 1992 or later models. They can be distinguished from the earlier models by being specific to the left and right sides. (The earlier straight blade rotors had just one model that would fit on either side.)
When you install them, make sure the correct rotor goes on each side, or you will overheat them even sooner. If you can see the vent blades as curved fingers, they should be pointing backwards at the top rotor.
Old May 2, 2004 | 06:02 PM
jkorreck's Avatar
jkorreck
I did a brake job on a 94 aerostar last fall and the rotors I bought were straight vented. Is the curved vents a ford oe part thing?
Old May 3, 2004 | 03:24 AM
xlt4wd90's Avatar
xlt4wd90
JKORRECK,
I got my directional rotors with the curved vent blades from a company called Autospecialties. I forgot exactly where I ordered them from. Note that they also make cross-drilled and slotted rotors, but I would avoid those for a street car. They will not last as long.
Old May 3, 2004 | 10:35 AM
copper_90680's Avatar
copper_90680
Bought mine from Autozone. Check their online catalog.
