Sponsored by: Kumho
Squeaking Sound When Turning
Old May 2, 2004 | 11:16 AM
F250 V10's Avatar
F250 V10
Question Squeaking Sound When Turning
Hey guys got a little problem here. I wanted to check in and see if anybody has ever had this problem and if so if its possible to fix without having to take it to a repair shop. The problem is when i go to make turns more so right turns there is a squeaking sound similar to when your break pads need changed. It also does it sometimes when i start to take off from a complete stop. Any help will be greatly appreciated. Thanks.
Old May 2, 2004 | 05:35 PM
Beast12's Avatar
Beast12
Maybe your bearings? Try repacking them. Also, when is the last time your front-end was greased? Try getting a grease gun and greasing your ball joints, tie-rod ends and any other grease nipples you can find. Also do your u-joints while you are at it. Good luck.......
-Matt
Old May 3, 2004 | 04:01 PM
brettenglund's Avatar
brettenglund
I have been having the same problem for a while now. If you figure it out please email me.
Brett
Old May 3, 2004 | 04:44 PM
F250 V10's Avatar
F250 V10
I will let you know. I just figure on taking it in to get repaired unless someone post within the next few days or so with a solution. But either way I'll let you know.
Old May 3, 2004 | 04:51 PM
brettenglund
appreciate it.
Brett
Old May 8, 2004 | 04:32 PM
brettenglund
Did you ever figure out what it was?
Old May 17, 2004 | 08:46 PM
heooj's Avatar
heooj
I had that too.
When turning at low speeds sounded like something grinding.
Front left bearing was shot. Had it replaced. Fine now.
- Randy
AkF250HD
Aug 7, 2013 06:31 PM
airjeff
Feb 25, 2012 08:50 PM
WickedSharp
Jan 13, 2011 09:10 PM
forddd
1997 - 2003 F150
Aug 10, 2006 10:22 PM
