Mixing Hollow and Solid Push rods
Old May 2, 2004 | 01:04 AM
46 Y-block's Avatar
46 Y-block
This is actually a question directed at 286 Merc. I noticed an older thread where you said to be sure not to mix hollow and solid pushrods. Just so happens my engine has a new though incomplete set of 11 hollow rods, and the remaining stock solids. Engine is 292. Agreed it is not a very tidy setup, and one that I plan on changing, but what are the real downsides?
Old May 23, 2004 | 12:45 AM
Janet40's Avatar
Janet40
Problems! Dear, get the solid push rods for your Yblock and be done with it. The lifters were designed in the "Y" for a smooth tipped solid type, a hollow will cause wear pattern issues, and you do not want to be changing lifter in a Y at all and this is because unlike a hydraulic lifter, in a Yblock, you have to remove the camshaft to change a damaged lifter because lifters are inserted from underside in a Yblock. I wouldn't want the unneccesary job if i could avoid it for sure for sure....Janet
Old May 23, 2004 | 09:00 AM
46yblock's Avatar
46yblock
The hollow lifters I have in use were made for a Y by I think Moroso. They have smooth tips.
special 55
31
Dec 18, 2015 05:34 PM
Js155
6.4L Power Stroke Diesel
May 12, 2015 01:11 PM
Crn316
Aug 25, 2014 12:04 AM
thrifty
Jan 15, 2013 11:19 PM
fordf350crazy
Mar 12, 2005 08:59 AM
