hot rodding the v10
hot rodding the v10
I have a 99 sd that i just recently threw a rod in. I need to rebuild the bottom end. Has anyone heard of some nice after-market pistons out there? Is a port and polish an option as well? I want to get this motor to make some serious power if i have to go through all the trouble of rebuilding the motor. i already have full exhaust and intake systems and crave more power. Besides a supercharger does anyone know of some mods like these?Can the compression be raised at all? I really want to get the most out of my motor while staying naturally aspirated.
Check the Mustang mags,Manley makes rods and pistons for the 5.4 and i believe they are identical.The long + small runner intake we have is a bottleneck in the intake for performance, but great for torque.Crower can make cams, but it will take 4months and about $600 per cam.Check with VT Engines, Sean Hyland Motorsports,JDM Engineering.You can check out my 2 gallerys and see my bolt ons which perform great.Good luck.
I will start researching about those possibilities and hopefully i can get what i need done for under 4 grand.Besides the machining, i will be doing all of the work myself. Do you know where i can look into the motor the guy was building for the crown vic? That would be sweet. i will definately keep you posted though because im sure there are a lot of people out there who just dont think that a supercharger is enough. that is definately in the works however but i think that's a little further down the road. has anyone been able to get over 550 hp out of one of these suckers? Thats what im looking for so any info is much appreciated.
Just my opinion...I'd stay away from JDM Engineering of NJ. (A) He's a Lightning tuner, supposedly, and (B) he talks out both sides of his mouth. In case you're not from the South, that means he can't be trusted.
If you want a strong motor, you could always use the Lightning stuff. All the v10 basically is a a 5.4 with 2 extra cylinders.
Here's a link to a website that talks about hopping up a v10. The guy who started the thread is really knowledgeable and has a decent website with links to other v10 sites.
http://www.modularfords.com/forums/s...ead.php?t=5610
HATCHETT
Dec 26, 2005 09:20 AM
proballer6968
Oct 18, 2004 04:16 AM
rdcouch
20
Jan 16, 2004 07:46 AM
