JBA EVOL Exhaust system.
Old May 1, 2004 | 12:15 AM
Dalamatition's Avatar
Dalamatition
I purchased myself a JBA EVOL stainless steel exhaust system for my 1993 F-150. I finally received it in the mail and WOW! 3 inch diameter pipe is just huge! My t ruck only has a 5.0 on it. This huge pipe will make my truck look like a diesel. It's so big that my engine will literally echoe in it as if my truck were in a cavern. This has me excited. Now all I need to do is replace the Y-shaped crossover pipe with a stainless steel Bassini replacement which is also 3 inches in diameter. My exhaust will have almost no backpressure.
Old May 1, 2004 | 01:17 PM
WhëëlMå1's Avatar
WhëëlMå1
I hope you like the catback. The bassani Y pipe is a great unit. I have one on my bronco (some clips are available from the link in my sig).
Rich
Old May 2, 2004 | 01:12 PM
Dalamatition
Do you have that Offroad Y-Pipe or the one with the crappy nonfunctional catylitic converters? My truck has dual catalytic converters on it. I'm wanting to get wrid of both of them and put on a 3" diameter Magnaflow stainless steel catalytic converter. Is that Y-pipe the correct length and everything? I'm going to use stainless steel Dynomax exhaust clamps to hold the whole shabang together as well as the clamps that came with my exhaust system. I don't want any welding. Information and advice is appreciated.
Old May 2, 2004 | 01:37 PM
WhëëlMå1's Avatar
WhëëlMå1
Nonfunctional?? Here in MA, we have some of the toughest emissions testing in the country, and I passed with flying colors with Bassani's high flow Y pipe w/ cats. Sounds to me like it was working fine. The Y pipe was the correct length for the Bassani catback I had one, but I had to shorten it for my current Gibson catback. I chose to stay away from welding too. I far prefer clamping.
Rich
Old May 2, 2004 | 02:16 PM
Dalamatition
The cats actually work? Wow. Bassini said it's not legal to put on emission controlled vehichles. They also said it's not a good stock cat replacement.
Old May 2, 2004 | 05:33 PM
WhëëlMå1's Avatar
WhëëlMå1
They have to say that because they did not seek a C.A.R.B. exemption number. It works just fine. Its 'not good as a stock replacement' because you arent putting two back on. The one high flow does the same job as the two stockers. It all comes down to how much money they want to throw away (ie waste on a CARB number). If you ask the guys in the bronco forum what they think, they will say the same that I have. There are many that run the same exact pipe as I, and NONE have failed emissions due to it.
Rich
Old May 2, 2004 | 08:39 PM
Dalamatition
Wow! That's great to know. Now I wish I didn't buy my JBA exhaust system. I kinda...planned on modifying the offroad version of that Y-pipe and adding a Cat on it that does have C.A.R.B. number. I'm runing the risk that the Y-pipe with a cat for my truck will be too long or too short. Hopefully it's just right but what are the odds?
Old May 2, 2004 | 11:32 PM
Dalamatition
Out of curiosity did the catalytic converter that came with your y-pipe have a 4 bolt flange on it?
Old May 2, 2004 | 11:37 PM
WhëëlMå1's Avatar
WhëëlMå1
The cat on the Bassani unit is welded in. They do offer both a slip fit (mine), and a flange assembly on the end of the pipe for mating with the catback.
Rich
Old May 2, 2004 | 11:47 PM
Dalamatition
Cool! My JBA exhaust instructions tell me to bolt my head pipe to the end of the converter pipe on the stoc catalytic converter. Is there a chance that the Bassani Y-pipe will be a few inches too short or a few inches too long?
Old May 3, 2004 | 08:04 AM
95soontobelifted's Avatar
95soontobelifted
If you run all 3" exhaust pipe won't you hurt the engine by not having enough back pressure? That is what I was always told.
Old May 3, 2004 | 06:02 PM
WhëëlMå1's Avatar
WhëëlMå1
I dont know. You might want to call Bassani and see if they can give you some size specs on your particular Y pipe, then compare that to stock, as well as the new catback.
Rich
Old May 3, 2004 | 06:05 PM
WhëëlMå1's Avatar
WhëëlMå1
Ah yes, the age old backpressure question. You never want backpressure. The less you have, the better. The problem? You need to maintain exhaust velocity . How do you do that? On standard auto engines, you cut down on the size of the pipe to keep the velocity high. That also causes backpressure. You basically have to walk the thin line.
Rich
Old May 3, 2004 | 08:47 PM
95soontobelifted
Question
rich- How do you know if you've crossed that thin line? I always wondered why the need for back pressure, people tell me it has to do with the exhaust valve burning if the smoke is evacuated to quickly.
Old May 3, 2004 | 08:58 PM
WhëëlMå1's Avatar
WhëëlMå1
Frankly, most people dont. You would need air velocity sensors (same way they rate the CFMs for carbs)to truly figure out the equilibrium. I use the baseline that a single 3" system will support up to 360rwhp sufficiently. I havent heard that valve burning idea, but that doesnt mean its could be a valid point.
Rich
