overheating 351M
Old Apr 30, 2004 | 11:39 PM
CETME's Avatar
CETME
overheating 351M
1978 F150 4x4 C6 here...
Truck will start to overheat after about 3-4 miles of driving..... Before I just start replacing stuff.... what is the most likely cause?
(there is fluid in the radiator)
I'm going to replace the thermostat tommorow.... if that doesnt work.... then I'll replace the waterpump, and the hoses.......
What do you guys think is the culprit here?
Old May 1, 2004 | 03:46 AM
Superdave's Avatar
Superdave
Radiator clogged up?
Fan shroud still there?
Did the problem just kind of appear?
Old May 1, 2004 | 03:54 PM
Torque1st's Avatar
Torque1st
Posting Legend
Does it overheat on the highway or in city traffic?
Old May 1, 2004 | 09:07 PM
CETME's Avatar
CETME
Wow... what an ordeal....
Turns out that the previous owner performed a ghetto rig on the brakes.... He installed a brake light switch behind the brake pedal, but it would not allow the pedal to come back far enough.... So the brakes were halfway applied all the time..... this wasnt a problem when he owned it.. but after I installed new F350booster/Mastercylinder ... new drums/shoes/wheel cylinders and then new calipers up front... it really caused a problem...
Heated up the engine pretty quick... but it was mostly the brakes that got smoking hot....
Now all I have to do is fix that busted ball joint =/
Old May 4, 2004 | 12:44 AM
Superdave's Avatar
Superdave
Crap!!
Well at least you know what the problem is now.
Clifford119
Testing.....
Aug 9, 2016 06:26 AM
FourDead
Jul 7, 2016 10:08 AM
kevin021092
1997 - 2003 F150
15
Jan 29, 2015 08:45 AM
5.4L to Freedom
Sep 8, 2011 06:39 AM
