Front End Question
Old Apr 30, 2004 | 07:43 PM
95_Ford XL's Avatar
95_Ford XL
Front End Question
I got a 81 Ford Ranger F-100 and I just lowered the front. I took it to the alighnment shop and they said that they can't do anything to fix it that it does not have a place for camber bushings. They said if I get F-150 I-beams that it will except a camber bushing. They said that you might also bend the I-beams but I didn't think that would be a good idea. What can I do to get the tires from looking like this / \?
Mike
Old Apr 30, 2004 | 10:44 PM
f100beatertruck's Avatar
f100beatertruck
I think that the older 2x4's had king-pin axles. They should be forged, not stamped like the newer ones, and if they are you can have them bent to line everything up. Look for a shop that does big trucks. Big trucks have straight forged axles with king pins and aligning them is as low tech as bending them. I'd just make sure they've done it before.
You could also get junkyard axles from a later truck. My 83 f-100 had stamped axles with ball joints and camber bushings in them.
Old May 1, 2004 | 05:19 PM
bremen242's Avatar
bremen242
My '84 2wd did not have any room for camber bushings. I think into the 90s they had stamped axles in most.
btw, I'm guess you just cut your coils to lower your truck, right? To do it right, you should get drop I-beams.. they have the camber already corrected in them
Old May 1, 2004 | 10:34 PM
DanMartin's Avatar
DanMartin
My 86 F350 (2WD) required the bending process like F100beatertruck suggests. Find a shop that has the equipment to do it without heating the parts (Which will weaken them). The guy I took mine to used a press and a special bridgework to bend them correctly (it actually took an extra day to do the work because he had to go dig the aparatus out of storage!). It does require some special skills that are not easily found, but the results for me were amazing. My 1-ton truck drives perfectly straight, and stops perfectly straight.
Right tool for the right job...
Dan
Old May 1, 2004 | 10:38 PM
bremen242's Avatar
bremen242
I've had my 2wd '84 f-150 bent back into alignment, but it always seems to go back out the same way after about 1 year..
