Sponsored by: Kumho
wheel hub assembly question?
Old Apr 30, 2004 | 04:55 PM
brettenglund's Avatar
brettenglund
Dealership says I need a new whel hub assembly on my right front. How much do these costs, where can I get one, and how much is involved with replacing it? Im no stupid when it comes to a wrench, but im no mechanic.
Old Apr 30, 2004 | 05:43 PM
1991_f250's Avatar
1991_f250
Front Hub
I am a Ford Partsman what kind of truck do you have if its a Super Duty it's a very common problem the front bearing is only serviced as an assembly and the abs sensor is part of the hub. Here they sell for about $500 dollars Canadian.
Old May 3, 2004 | 04:04 PM
brettenglund
I have a 2000 f150 4x4, I also have this squeeling problem with the brakes (or maybe the hub) onteh same wheel would that be the problem for the squeeling noise?
Brett
Old May 3, 2004 | 04:50 PM
Bordaine's Avatar
Bordaine
Changing the wheel hub is no big deal. I just did mine. It would have been an hour if I had bought new studs and nuts for the mount ( comes with wheel studs). 4 nuts,1 snap ring and 1 plug more work than doing the front brakes. If you have ESOF also get the O ring for the hub.
HiZ
Jan 12, 2016 12:47 PM
Headviking
Sep 2, 2014 06:44 PM
jaserlet
Nov 9, 2011 03:42 PM
homesteader
Nov 17, 2010 05:08 PM
elroy
1978 - 1996 Big Bronco
Mar 6, 2009 09:17 AM
