F150 Distributor install
Old Apr 30, 2004 | 11:49 AM
bigbadjs's Avatar
bigbadjs
I'm trying to install a new distributor in the above pickup. The shaft slides into the oil pump ok but the distributor flange wont seat against the engine block ( it hangs out about 1/4 inch ). The gears are engaged. I tried rocking and twisting the dis but with no luck, it just wont drop in. Is there a trick to installing this thing properly?
Old Apr 30, 2004 | 03:38 PM
RTM's Avatar
RTM
Its hanging up on the oil pump shaft. Try bumbing the key or turning the motor by hand and it should drop right in.
Old Apr 30, 2004 | 04:16 PM
bigbadjs's Avatar
bigbadjs
That did the trick ( turning the crank ) ... thanks...
Old May 1, 2004 | 01:54 AM
Superdave's Avatar
Superdave
Double check it to make sure the distributor is in the right tooth.
It will usually drop into the right tooth but sometimes if the engine rotates enough before the distributor drops in and seats against the block, it can be off a tooth.
KsCop
39
Dec 30, 2013 05:12 PM
Dana Jensen
Apr 21, 2007 07:58 PM
LEckart
May 4, 2004 03:03 PM
78Bill
Sep 8, 2002 03:03 AM
