Engine braking
Old May 6, 2004 | 08:17 AM
  #31
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Originally Posted by SBV45
Desert Racer, are you looking for a buy back, trade up? Is this based on the tow/haul mode or other things?
This could be the first one based solely on the tranny brake.
Old May 6, 2004 | 12:50 PM
  #32
desertracer's Avatar
desertracer
I'm not looking for a buy back, but if my dealer and or FMC can't fix my truck then so be it. My dealer is suposed to call me when DR can check out truck and try his hand at
geting it fixed.
I have had the same problems as most-bad injector #2 rough idle etc. all fixed but braking.
Old May 6, 2004 | 02:30 PM
  #33
desertracer
Just talked to FMC rep he is to call me back on monday. Will let everyone know what happens.
Maybe just maybe FMC will fix all our trucks that have no engine or tranny braking.
Don't hold your breath!!
Old May 7, 2004 | 07:42 PM
  #34
ono's Avatar
ono
E series Torqueshift
Anyone know why the 04 Econoline 6.0/Torqueshift has no T/H mode? It only has the ordinary O/D cancellation button. This is the first year of this eng/trans in the E series. Considering the limitations of this trans application and the engine output of only 215hp & 440lbft torque the option price of $4800 seems hefty.
Old May 7, 2004 | 08:34 PM
  #35
ono's Avatar
ono
Old May 7, 2004 | 10:13 PM
  #36
Tadashi's Avatar
Tadashi
I always thought that was the same thing. They just renamed it. Is that true?
Old May 7, 2004 | 11:36 PM
  #37
ono's Avatar
ono
Not at all the same thing. The O/D cancellation only does that--prevents trans from shifting into overdrive. The tow/haul mode in the torque shift trans allows all shifts but at higher rpms for same throttle pressure, plus it allows for engine braking by downshifting on decelereation and somehow works in conjunction with the brakes. Don't know too much about it siince I don't have one, maybe someone else can chime in. Hope this helps some.
Old May 9, 2004 | 08:38 PM
  #38
SBV45's Avatar
SBV45
I just got back from a 370 mile round trip to the Texas Gulf Coast and back pulling my boat. Boat, trailer and "stuff" weigs about 2000#. I see no difference between tow/haul mode in 4th and 5th gear above 45 mph and not being in tow/haul mode. In tow/haul mode doing 65, take my foot off the accelerator and tach goes to 1000 rpm or so. I hit the brakes lightly or stand on them there is no difference until 45 mph then it aggressively gears down and the TC locks up the the RPM jumps up and uses the engine for braking.
If it is doing something in 4th or 5th gear in tow/haul mode above 45 mph, I don't know what it is.
Old May 9, 2004 | 09:23 PM
  #39
IB Tim's Avatar
IB Tim
It is not working
Old May 10, 2004 | 06:42 AM
  #40
SBV45's Avatar
SBV45
I forgot to mention I have an 03 engine with flashes through Dec 03 (the latest for the 03).
Old May 10, 2004 | 06:49 AM
  #41
IB Tim's Avatar
IB Tim
That explains it, the Dec flash disables the TB
Old May 10, 2004 | 10:32 AM
  #42
SBV45's Avatar
SBV45
what really gets my grits going the wrong direction, is that the dealership never told me what were the downside of a flash. I got the Oct flash because it was supposed to fix an intermittent, really rare, idle issue. No one said anything about pilot injection removal, etc. Same with the Dec flash. If someone would have said something about the downside, I never would have had it done.
Old May 10, 2004 | 10:55 AM
  #43
Tadashi's Avatar
Tadashi
So if I still have stock flash (RC1) does that mean I still have pilot injection and the tyranny brake?
Old May 10, 2004 | 12:31 PM
  #44
IB Tim's Avatar
IB Tim
I am with you on this one..
Old May 10, 2004 | 02:47 PM
  #45
Choctaw Bob's Avatar
Choctaw Bob
If your engine was built before 5/03
