92 4x4 switch
Old Apr 28, 2004 | 10:52 PM
FLGator's Avatar
FLGator
92 4x4 switch
My 92 Explorer 4x4 switch will not activate the transfer case. I've checked the switch and it reads low voltage to the wire that sends power back to the electronic shift control module. This low voltage is virtually nonexistent on the same wire that plugs into the module but I can send 12 volts through it when I bypass the switch. Has anyone else experienced 4x4 engagement problems caused by an electrical failure?
Old Apr 29, 2004 | 06:55 AM
Traveleast's Avatar
Traveleast
Many moons ago I had a 92 XLT with the electric 4wd switch. It failed....had to replace the servo? that actually does the shifting in the transfer case. Close to $300.00 job 7 years ago.
Old Apr 29, 2004 | 08:48 AM
Opera House Works's Avatar
Opera House Works
The likely problem is the "shift motor". You can clean and lube these yourself if you want to save money. I did mine. Just search back a little. Every other day someone posts with the same question.
superhooperduty
Oct 15, 2013 01:31 PM
Red Ex
Jan 21, 2012 03:39 PM
Red Ex
Oct 10, 2011 11:22 PM
frontco
Electrical Systems/Wiring
Nov 8, 2004 07:51 PM
Goldenace
1978 - 1996 Big Bronco
Mar 24, 2004 05:36 AM
