Glow Plug Control Module
Old Jul 24, 2002 | 10:06 PM
78RangerXLT's Avatar
78RangerXLT
I am helping my boss hook up his diesel ignition the correct way. Right now it has a manual switch for the glow plugs and he frequently burns them, being 8$ a Motorcraft glow plug this gets to be rather expensive and he has to plug in his truck on a 80* night like tonight. He has a glow plug control module but we have no diagram to properly install the wires on the terminals. I would greatly appreciate if anyone could could lead me to a diagram as his Chilton's manual doesent help a thing. Thanks a lot!
Old Jul 24, 2002 | 10:14 PM
Brian460's Avatar
Brian460
What year?
Brian:P
Old Jul 25, 2002 | 11:46 AM
78RangerXLT
It is a 1990 F350 Lariat with a 7.3L 445CID International
Old Jul 25, 2002 | 01:34 PM
Brian460's Avatar
Brian460
Is all the factory wiring and connnectors still intact? If so I will go look a mine (which is sitting in the back of the truck) and tell you what wires connect where.
Brian
Old Jul 25, 2002 | 01:42 PM
78RangerXLT
Yes, all of the wires are in tact, the previous owners just bypassed the control module due to its earlier failure with Romex wire connected to a switch in the cab, then to the glow plug leads. We have a new International control unit. Everything looks good under there. I appreciate your help. Thanks
Old Jul 25, 2002 | 03:51 PM
Brian460's Avatar
Brian460
[updated:LAST EDITED ON 25-Jul-02 AT 04:53 PM (EST)]I am going to assume that the new unit comes with the wires from the bootom of it already attached to there proper points if not let me know. Here is the rest.
Looking at the top of the unit when mounted in engine compartment.
1_________________2_________________3
4_________________5
Numbers representing terminals
1. 2-10awg yellow wires
2. 1-14awg red w/ green stripe
3. 2-10awg brown (feeds glow plugs) and 1-14awg green
4. 1-14 yellow should be factory terminated on controller.
5. 1-14 yellow from controller and a steel bar going to terminal 3
Let me know if you run into more problems
Brian
Old Jul 25, 2002 | 09:43 PM
78RangerXLT
Thats great, thanks a lot!
Old Jul 25, 2002 | 11:34 PM
FTE Ken's Avatar
FTE Ken
croweyes
Nov 10, 2014 09:06 PM
hardwaterfreak
Oct 5, 2012 09:21 AM
brian42
22
Jan 2, 2011 08:20 AM
gfemling
21
Jun 5, 2009 11:33 PM
sturoe
25
Mar 21, 2007 09:37 PM
