Sponsored by: Real Truck
Leaf spring recall???
Old Apr 28, 2004 | 06:05 PM
kensnewtruck's Avatar
kensnewtruck
Question Leaf spring recall???
After telling a buddy of mine about the front end of my 03 F250 5.4L CC SB feeling pretty loose he said; in his they built the truck with the 1/2 ton leaf springs instead of the correct 3/4 ton springs. The front of the truck does droop a little but from what I hear they are supposed to look that way. I did a search through the forums and didn't come up with much. Just wondering if anyone else had these springs replaced, or if my buddy think he knows more than he does. The later of the two is probably more correct
Old Apr 28, 2004 | 06:50 PM
mattsf250's Avatar
mattsf250
1/2 trons do not have front leaves...and have not for a long time.
n578md's Avatar
n578md
Looking at my 2003 manuals for the F150 and Super Duties, the front "springs" for an F150 4x4 are torsion bars so they obviously didn't use that. The rear springs for the 150's are only 2.5" wide where as the Super Duties are all 3" wide. If you measure your front springs and they are 3" wide, then they are most likely the correct type. No? (unless they used 2004 F150 springs which are now 3" wide, but less likely on a 2003 F250)
Old Apr 28, 2004 | 07:01 PM
kensnewtruck
Thanks for the info - any other ideas on what might cause it? ive been looking at replacing the shocks and adding a steering stabilizer - my 250 didn't come stock with one. think that would help?
Old Apr 28, 2004 | 08:47 PM
99f350sd's Avatar
99f350sd
What spring code do you have? I have a set of w's I'd like to part with..
http://www.carnegiebody.com/pfffgawr.htm
Old Apr 29, 2004 | 03:09 PM
kensnewtruck
I've got t's - I'm going to be adding a plow this winter (8' Fisher) Adding heavier springs - would that increase stability and control??? And would that raise the front end a bit? and last but not least, how much???
monstertrucker
21
Feb 23, 2014 04:16 PM
Robby Nash
Jan 14, 2014 10:46 AM
bigteal
Feb 18, 2013 12:18 PM
Bender99
Offroad & 4x4
Nov 22, 2009 11:07 PM
beemr
Jan 30, 2007 10:50 AM
