Psd Full Service????
Old Apr 27, 2004 | 09:28 PM
WyBlackhawk's Avatar
WyBlackhawk
I just bought my truck and dont have a owners manual so I have a few questions about some fluids?
Transmission Oil:
Engine Oil:
How Much?
What Type?
Is there a Royal Purple equivilant (And do you recomend it?)
Any Particular Oil filter work better than others?
Thanks Alot
Old Apr 27, 2004 | 09:48 PM
johnsdiesel's Avatar
johnsdiesel
What year is your truck?
Old Apr 27, 2004 | 09:58 PM
WyBlackhawk
2001 4x4
Thanks
cleatus12r's Avatar
cleatus12r
Butt-Head
What transmission?
Old Apr 27, 2004 | 10:00 PM
WyBlackhawk
Automatic
Automatic with overdrive
Not sure other than that but I can go look if you need a specific number
Old Apr 27, 2004 | 11:02 PM
WyBlackhawk
Help !!
If anybody could help with my original question I would be very grateful.
Old Apr 27, 2004 | 11:31 PM
Bigsilver95's Avatar
Bigsilver95
Transmission Oil:
Engine Oil:
How Much?
What Type?
Thanks Alot
Oil, something 15W40. Diesel rated, rotella, delo, something like that. I use rotella. get a motorcraft filter, you can get them at walmart. 10 bucks. Tranny, dont know, have a 5 spd
Old Apr 28, 2004 | 04:32 AM
CAT_man_963's Avatar
CAT_man_963
2001 4x4
Thanks
Oil - 15w40 - should be right around 15 qts
Auto Trans - Mercon atf fluid (not Mercon V) - 18qts
Old Apr 28, 2004 | 06:46 PM
bigpowerstroke's Avatar
bigpowerstroke
O.E. spec show to be Mercon V transmission fluid for the transmission. The only other place that there is dexron/mercon III is the power steering.
Old Apr 28, 2004 | 08:32 PM
mybigredford's Avatar
mybigredford
i got a 02, and i changed the tranny fluid and my manual, and dipstick says to use mercon only, i used some penzzoil brand atf fluid that was mercon/dexron rated and seems to be working fine, just thought i would tell you what i did.
Old Apr 28, 2004 | 09:40 PM
mwierowski's Avatar
mwierowski
Found a place to download the manuals http://www.genuineflmservice.com/default.asp?page=E4
-Mike
Old Apr 29, 2004 | 10:39 AM
78fordman's Avatar
78fordman
My 00 specifies Mercon V and not anything else. Make sure to use a good filter, pretty much anything but fram. Use a diesel rated oil ( C series of certifications ). I use Rotella T, great oil. Make sure to service your cooling system about every 60K, put in new coolant and add anti-cavative additive, otehrwise your diesel will go to waste in a shrot order of time. Change tranny fluid every 30K, I would use V to be safe, V is backword capabil with III.
Old Apr 29, 2004 | 11:22 AM
FarmerPhilCo's Avatar
FarmerPhilCo
fram used to be good until they were bought by a company that makes lightbulbs
Old Apr 29, 2004 | 05:47 PM
CAT_man_963
Huh - my '02 specifies in the manual Mercon and NOT Mercon V or even dual usage Mercon/Mercon V. What's going on here???? Aren't these all the same transmissions??
