powerless powerstroke
Old Aug 5, 2002 | 04:45 PM
gene1111's Avatar
gene1111
Post powerless powerstroke
I have a '94 350 7.3 turbo diesel direct injection manual 5spd that doesn't have any *****. It's the first one I've owned and I thought it would have a lot more towing power than it does. It only has 65000 miles on it. I pull a fifthwheel trailer with it and when I hit a grade of any sort I eventually wind up in 3rd gear at 35mph. It sure blows a lot of smoke pulling uphill but doesm't any other time to speak of. It has a dualmass flywheel and 4:11 gears so it seems like it should pull a little better than this. Any help or suggestions would be greatly appreciated.
Old Aug 5, 2002 | 09:05 PM
theologian's Avatar
theologian
I cannot think of what is wrong, with such little information, but it is most definitely a sick truck. You should not be able to say that of a powerstroke, so you need work done on it.
Wm
'96 F450 White with Grey interior Crew Cab. Banks Turbo, Intercooler and Exhaust,
Power pack Chip, shift kit, Auxiliary transmission, electronic enhanced transmission control,
16 forward and 4 reverse ratios. 340hp 660ft lb 4 wheel drive, 4.10 gears, 12,ooo# winch
Old Aug 5, 2002 | 11:29 PM
myst's Avatar
myst
I would change my air and fuel filters and see what that does.
Old Aug 6, 2002 | 08:00 AM
powerstroker250's Avatar
powerstroker250
Have it scanned for codes.
Les
Old Aug 7, 2002 | 04:39 PM
gene1111's Avatar
gene1111
>Les
Thanks for the reply, I'll do that
Gene
Old Aug 8, 2002 | 05:25 PM
chaynes171's Avatar
chaynes171
I have a 94 F350 7.3 as well. What are the first steps to getting more power? I'm not too impressed with it as is. It has 35's lift kit and I need it to pull a 10K # trailer. It is a 5 speed.
Thanks for the info.
Old Aug 9, 2002 | 12:03 AM
myst's Avatar
myst
