Bad rust over rear wheels
Old Apr 27, 2004 | 02:00 PM
dpbrowne's Avatar
dpbrowne
What is the best way to correct the wheel wells from rusting out? Rear wheel wells are starting to show rust and holes.
Old Apr 27, 2004 | 03:09 PM
optikal illushun's Avatar
optikal illushun
fact of the matter, our trucks (87-96) have been notorious to rot, especially in the snow belts. water, salt and crud build up under the wheel well lip in the underside thanx to ford doing a double wall inside. this doesnt dry out and allows oxidation to start. trust me, i have talked to many body shops about it and the same response was given from all...
the best way to fix it is have a body shop cut the rotted section out, weld in a new patch panel and paint it. also, if possible try to coat the wheel wells with some kind of rust inhibitor like POR-15, rustoleum (the thick, heavy kind) or even rubberized coating after u clean it out good and let dry.
Old Apr 28, 2004 | 09:15 AM
dpbrowne's Avatar
dpbrowne
Thank you. I was hoping there was a less expensive way. Dennis
Old Apr 28, 2004 | 10:51 AM
recxr7's Avatar
recxr7
POR-15 is awsome, I also use a paint from True Value Hardware stores called X-O Rust Red Mateal Primer, it takes a long time to dry but seals very well. I usually let it dry for a week or a month. POR-15 drys much faster and is a better product but more $$
Old Apr 28, 2004 | 04:35 PM
optikal illushun
there is a less expensive way but its half assed way of doing it...:-/. u can bondo over it and paint over it but rust is like cancer and it keeps comin back. sorry to say the cold hard facts. the average price to fix wheel well rot is around $7-800 for both sides and half if its for one side. that is for a new panel welded in, prep, primer, paint and wet sanding/buffing.
Old Apr 28, 2004 | 05:23 PM
RTM's Avatar
RTM
One trick to stop it from rusting or ever starting is to spray used motor oil inside the panels, doors and such. I soaked my tail gate with gear oil. Its sticky stuff.
NHman
Jan 6, 2014 11:03 AM
aphiman
Jun 11, 2011 12:08 AM
anthony605
16
Aug 24, 2007 04:44 PM
phoneman91
Dec 12, 2005 03:26 PM
golfboy17
Jun 1, 2004 07:30 PM
