Cheap Fix for Cyl Heads...HELP!!!
Old Apr 27, 2004 | 11:44 AM
79F150400M's Avatar
79F150400M
Guys, need some advice here. I'm on a tight budget these days. (unemployed). But gotta have me truck running. I have a cracked exhaust valve. Heads were rebuilt not long ago...was hoping i could just replace the valve as long as all the others were OK. Colors look normal. INtake valves are abit carboned...exhaust valves are nice and tan....Whaddya think??? Do I need to do any serious rework here????
Old Apr 27, 2004 | 12:19 PM
beartracks's Avatar
beartracks
Is it cracked or burned? You probably have damage to the valve seat. This could have come from too little clearance in the lifter or a push rod not fully seated in the lifter. I would think if you have it off to at least lap the seat.
Old Apr 28, 2004 | 12:49 AM
79F150400M's Avatar
79F150400M
Valve is cracked in three places. Got the damage confirmed today. Mechanic at local machine shop took one look and said,"Your screwed!!!" So it looks like the cheap n easy route is out. Need hardened seats. Three out of 4 exh. valves on one side are sunk in. Thanks for your input.
