Sponsored by: Real Truck
Rims, backspacing, offset...
Old Apr 27, 2004 | 11:09 AM
basstardo's Avatar
basstardo
Red face Rims, backspacing, offset...
Alright folks,
I'm fixin to buy some new rims and tires for my rig. I have a 6" lift, and I'm planning on running 16x10 rims with PJ Dirt Grips that are 36x14.5R-16. The rims I'm lookin at are Weld Scorpio's:
16x10 8x170 Backspace - 3.625 Center bore - 4.93
Will that backspace work with those tires without fryin my suspension components? Also, what does "offset"?
Thanks,
Terry
Old Apr 28, 2004 | 01:23 PM
Super Steve's Avatar
Super Steve
Offset is how far off center the mounting surface is. Backspacing is how far the mounting surface of the rim is to the lip. A 10 inch wide rim with 3.625 backspacing is going to be offset 1.375.
Old Apr 30, 2004 | 02:01 PM
fxstc80's Avatar
fxstc80
IMO...Would probably be allright for your suspension but I wouldn't do that to my bearings.......That tire with such little backspace will stick way out if that's what you looking for.
Old Apr 30, 2004 | 02:44 PM
basstardo's Avatar
basstardo
I'm not necessarily lookin for it to stick out. The look is cool, but I don't wanna be replacing wheel bearings every 5000 miles either. I drive this truck 45 miles each way to and from work, and put about 200 miles on it every weekend, so I need longevity. What would the recommended backspacing be for this? I heard 4.5 or 4.25 a while back, but I can't remember if that's right, and I don't know how the width of the tire will impact that.
Terry
Old Apr 30, 2004 | 03:04 PM
TrunkSlammer's Avatar
TrunkSlammer
Look Here http://www.usacomp.com/Offset.htm
Some stuff http://www.dsm.org/tools/tiresize.htm
Old Apr 30, 2004 | 10:28 PM
fxstc80's Avatar
fxstc80
I shopped for tires and wheels for a long time....I didn't want mine to stick out past the fender because I don't like that look, some do though. I went with a 4.5 inch lift, 315/75 (35X12.1) on a 16X8 rim with 4.25 backspace. They sit flush with the outside of the fender. That same tire and backspace on the same wheel in a 10 inch will stick out about 1 inch. They're on trucks at a dealer near me. Given my preferences for looks if I had a 6 inch lift I would stick with a 37X12.50R17 on a 17X8 with at least 4.25 BS, take the 4.5 if you can find it in a wheel you like(good luck there). That fills the wheel well but does not stick out and looks great IMO. I really don't think a 10 inch wheel with at least 4.25 BS will stress your bearings much but I would be wary of Weld's 3.625 BS. Someone will come along and say they run 12 inch wheels with no problems.....but not for me....hope this helps
Old May 1, 2004 | 01:58 PM
Super Steve
I agree. I went with 17x8 and 37x12.5's and I believe they were 4.5 inches of backspacing. They don't stick out past the fenders and they should keep the load centered between the bearings.
Old May 3, 2004 | 08:51 AM
basstardo's Avatar
basstardo
Are there any issues with airing down on a rim that's 17"? That's the whole reasone I wanted to go with a smaller rim of 16" or so. I don't know if it makes that much difference, and I really don't do much serious wheeling, but going to Hatteras and driving around on the beach I really need to air the tires down cause that diesel is HEAVY! The 17's do sound like they would look nice though. Thanks for the help guys...
T
FordF100man
Nov 7, 2015 01:52 PM
FordF100man
Offroad & 4x4
Oct 29, 2015 08:27 PM
duff429
Jan 23, 2013 02:51 PM
Bob_91SC4x4
Aug 7, 2010 02:59 PM
raldo_gtm
Nov 2, 2004 11:37 AM
